cut brake hose too ...
[Closed] cut brake hose too short
Where do I go fron here? Buy new hose fit then bleed? How do i Drain the remaining Fluid from the lever and caliper ?
Posted : 26/04/2014 12:32 am
Yep, but put it back together and see how much fluid you can save in there. unless it's a front already keep it for a front spare. Bleed as per the intructions for your brake.
Posted : 26/04/2014 12:59 am
 gogg
Oops.
Measure twice, cut once as "Timber Thompson" my woodwork teacher at school used to say.
Posted : 26/04/2014 11:03 am
Will any replacement Shimano hose fit? Do all shimano hoses come with with the banjo bit already attached?
Posted : 26/04/2014 4:05 pm
Anyone?
Posted : 26/04/2014 9:17 pm
 gee
The replacement hoses come with everything you need.
Just make sure you order the right one - either straight (like Deore) or banjo (like XTR).
Posted : 26/04/2014 9:28 pm
My brakes are XT, I take the XTR one will be compatible?
Posted : 26/04/2014 9:56 pm
How old? My XT's (775's I think) are straight fit, no banjo
Posted : 26/04/2014 10:39 pm
Pretty sure you need the deore hose bh90 of they're the m785 brakes
Posted : 26/04/2014 10:53 pm
I was cutting Shimano hoses today, and I said to the missus 'Measure Twice, Cut Once'.
You can learn by making mistakes, you're unlikely to do it again - so that's the good news ๐Ÿ˜‰
Posted : 26/04/2014 11:27 pm
