Creaky bars/stem
Creaky bars/stem
 Moe
My riding buddy recently bought a new Merida hardtail the flat wide bars we swapped for some slightly narrower risers to see if it would help his back.
The stem has a two piece clamp and it creaked like a b**ch, even swapping back still creaking!
Any suggestions as to a remedy? TIA.
Posted : 27/02/2024 4:10 pm
Taking apart,cleaning, copaslipping and reassembling with a torque wrench and correct torque fixed my levo which was going through a hammer house of horrors phase.
Posted : 27/02/2024 4:19 pm
zerocool and zerocool reacted
What towzer said but I use carbon paste rather than copperslip.
Posted : 27/02/2024 4:44 pm
Personally I'd buy a cheap higher rise stem (lots of decent options on SJS Cycles) - better way to ease your mate's back issues, and also allows you to double check that's actually what's causing the creak. Always good to have a selection of stems with different lengths and rise in the spares box when setting up a new bike; you can always go more gucci later when you're happy with what you need, although I'm of the opinion a stem is just a metal stick that puts the bars where you need them.
Posted : 27/02/2024 5:23 pm
One miniscule bit of sand or something getting in between the bars and the stem faceplate can cause a hellish creak.
Posted : 28/02/2024 12:49 pm
My bars and stem drove me absolutely nuts until I greased my headset and then they were absolutely fine.
Posted : 28/02/2024 12:55 pm
