Creaking Turner
[Closed] Creaking Turner
I put my 5Spot together about 2 months ago and everytime i have been out on it it creaks like crazy.
i have taken apart the whole drive train, chainrings, BB and cleaned and greased it but with no success.
It creaks on nearly every pedal stroke when putting the pressure on. This can be replicated by holding the bike upright and applying pressure to one of the pedals when not sat on the bike!
Has anyone any ideas?
Posted : 02/08/2010 9:37 pm
Have a look on the Turner forum on MTBR.
If it's a DW link Turner it could be the linkage pivots.
Posted : 02/08/2010 9:39 pm
yes it is a dw link.
i dont think its the suspension because when i dont put pressure on the pedals and bounce on the suspension it is silent through its travel. This lead me to believe it was the drive train.
Posted : 02/08/2010 9:41 pm
Well as you've not cured the problem you might be looking in the wrong place. ๐Ÿ˜‰
My money would be on the linkages creaking when side loaded.
I had a Sultan out on test that had the same problem.
Posted : 02/08/2010 9:48 pm
Dry or loose pedal, bb or chainring bolt threads.
Posted : 02/08/2010 9:54 pm
its not the pedal because when i ride along clipped in it doesnt creak.
took all the BB and chainring bolts apart and cleaned and greased them with no success.
Posted : 02/08/2010 10:15 pm
overpriced merkin tat
Posted : 02/08/2010 10:16 pm
Pedal threads
Posted : 03/08/2010 12:59 am
Have you looked at the rear hub/cassette?
Posted : 03/08/2010 2:40 am
it's a known problem for 09 dw frames
search on mtbr turner forum for 'creaking flux' or suchlike - something to do with the pivot bolts IIRC.
Posted : 03/08/2010 7:52 am
It is most likely the pivot bolts, Turner - if you contact them will send you some new stainless steel ones. I think they refer to them as 'sex bolts' - not sure why but it stopped the creaking.
Also, try pumping grease into all the zirc grease ports - sometimes it is a bedding in issue.
Good luck
Shiny
Posted : 03/08/2010 7:57 am
As rexated said it's a known problem.
Email greg@turnerbikes.com and he'll send you new shafts with deeper grooves.
That fixed my creak.
Posted : 03/08/2010 8:11 am
Is there an echo in here. ๐Ÿ˜‰
Posted : 03/08/2010 8:12 am
My DW Flux was bad - turned out to be the mech hanger. Took off, cleaned, & covered joining faces with copper Slip.
Posted : 03/08/2010 8:56 am
 jsm
My old 5spot creaks if any of the main linkage bolts are not tight enough. Use a torque wrench to check. Once in a while I checked them.
Other sources of creaks, external bb, bash ring bolts and crank bolts. Usually a bit of grease and threadlock sort it out.
Posted : 03/08/2010 9:39 am
Possibly the hex links. Greg will send out a pack with everything you need for free pretty quickly - I got mine in a few days. Also check the little inserts for the rear brake calliper adapter. You can put some grease on them too.
For the record, mine has never creaked or squeaked (touches 'wood').
Posted : 03/08/2010 12:03 pm
 nuke
Interesting as my new 09 Flux creaks a bit. Always thought it was the saddle...off to the shed for a bit of testing
Posted : 03/08/2010 8:25 pm
just an update.
emailed Greg @ Turner and a new set of 'sex' bolts and pins are on there way to me.
Will keep you updated on the progress of my creak when i get the new set in.
Posted : 03/08/2010 8:33 pm
