Creaking Orange 5
[Closed] Creaking Orange 5
[#2974995]
I'm getting a bit frustrated with this now, Maybe the singletrack masses can help me....
Makes a horrible creaking when peddling under pressure (going up hill, high gear etc) and does so when in and out of saddle
Doesn't make any noise if I just compress the suspension.
I have changed the pedals and bottom bracket, cleaned and changed the seat post and clamp.
Am I just left with the pivot bearings, but I would have though they would make noise if I compressed the suspension..
Any ideas?
Thanks
Z.
Posted : 23/07/2011 3:29 pm
Did you clean and grease the chainring bolts? They dry out and bind on the rings and once cleaned and then greased up hey presto no noise.
Posted : 23/07/2011 3:40 pm
just did the pivot bearings on my pitch, they only creaked under load and were silent when pushing down on the saddle.
A mates orange 5 had a creak, it turned out to be the raceface cranks undoing themselves (faulty)
Posted : 23/07/2011 3:45 pm
Deffo the rear skewer assuming you have quick release. You can try removing and cleaning it and the drop outs and reattaching to see if the problem goes away temporarily. Alternatively if you have another bike swap the skewer from that to see if it goes away. A few on here have put a 10mm skewer in but that requires some extra hub parts (axle I think). See http://www.singletrackworld.com/forum/topic/creaking-orange-5-solved
Posted : 23/07/2011 3:47 pm
Was the rear QR on mine, needs to be bastard tight to avoid the creak. Could also be the shock mounts.
Posted : 23/07/2011 3:53 pm
TFTuned heavy duty shock mounts solved it on mine.
Posted : 23/07/2011 4:01 pm
Prizes go to Scuttler and Richpenny!
Changed the QR and its gone, thanks so much for the help!
Did also clean refit the pivot bearings, which wasn't as scary as I thought i would be, good thing to have learnt for future I guess!
Thanks again
Z.
Posted : 23/07/2011 4:13 pm
Yep QR on mine too!
Posted : 23/07/2011 5:01 pm
I too have the creak, exactly the same symptoms - but no QR on the rear.....I was thinking it was BB, was just about to order a new one, but may have to investigate further.......
Posted : 23/07/2011 5:24 pm
Pro 2 axle snapped on my five with maxle, creak you describe
Posted : 23/07/2011 5:31 pm
Take an angle grinder to it. That will stop the creak..... 😆
Posted : 23/07/2011 5:52 pm
Thanks to the responses on this thread my mates Orange Five that was creaking like an annoying creaky thing was solved when we pulled over at the trail side popped out his hope rear skewer oiled it with my emergency oil pot popped it back in and ahhh peace and quiet. My mate thought I was the dogs danglies and that I had thought about the solution myself so I kept up the pretence till the end of the ride then spilled the beans.
Thanks STW 🙂
Posted : 23/07/2011 8:23 pm
+1 for the rear QR as well! Didn't matter how tight I did it up including lubing it, it still creaked. Changed it for a Shimano Deore one I think and now totally silent. Go figure? 😀
Posted : 24/07/2011 4:26 pm
Chainring bolts, like Hadge says. They were the culprips on my creaking Heckler.
Posted : 25/07/2011 12:38 pm
