XTR cables, only about 3 week old - and they creak like a bugger! still work fine but the creak is doing my nut in. whats the best way to cure it? grease?
Posted : 11/05/2010 1:38 pm
The cables on my last bike creaked & I traced it to the outer being a bit long and moving the ferries in the cable stops. A bit of trimming improved it but never got completely rid.
Posted : 11/05/2010 2:10 pm
Same as above, it was the cable ferrules that creaked on mine, was using clarkes cables with metal ends.
Posted : 11/05/2010 2:12 pm
If they run under the bottom bracket, stick a bit of oil/grease in the channel the cable runs through. Worked for me ๐
Posted : 11/05/2010 2:13 pm
Ferrules and frame cable guides need cleaning & a bit of lube.
Posted : 11/05/2010 2:40 pm
