Creaking clicking n...
[Closed] Creaking clicking noise
E-thirteen TRS double crank 22/36 and bottom bracket.
Under load there's a click/clonking noise which appears to come from the right side when the pedal is at about 2 o'clock.
Only does it when the chain is on the 22th chain ring. Nothing when on the 36th.
So that irons out pedals. Not the saddle either/seat post as it still does it out the saddle.
I have checked the pre-load adjuster.
Any ideas?
Canyon Dude 9.0
Posted : 26/03/2017 9:44 am
remove grease and refit mech hanger and both wheel axles for starters.
Posted : 26/03/2017 9:53 am
 dyls
Make sure the skewers are tight as well when you grease them.
Posted : 26/03/2017 10:02 am
If it only does one it one ring clean and lightly grease the chainring bolts, after that it's just going over the bike and checking absolutely everything cos it could be just about every single part attached to the frame from the wheel axles to the headset and pretty much everything in between..
Posted : 26/03/2017 10:12 am
