Creaking bottom bra...
[Closed] Creaking bottom bracket
Getting some occasional creaking from my bottom bracket when I stand on the pedals. Time for a new one?
What should I be looking at paying in a LBS to supply and fit a new one. Think I've got ISIS one in there at the moment, probably a cheap one.
Posted : 02/07/2010 10:17 am
Is there play in the cranks ? Side to side ? If not, try greasing first...if you've got the tools that is.
Posted : 02/07/2010 10:32 am
Not noticed any play. Haven't got the tools, never bothered buying them as thought the amount of times that I would use them would just be cheaper to pay someone else to do it.
Posted : 02/07/2010 10:41 am
Clean the bike, drop some oil onto the crank/BB interface then try again.
If it's intermittent, I doubt it's the BB or the crankset that need replacing - just a bit more TLC.
Posted : 02/07/2010 10:43 am
Ok will try a bit of oil in there and see how it goes.
Ta.
Posted : 02/07/2010 10:47 am
Check chain ring bolts too. Often one can assume its the bb, but it could be several other things.
Posted : 02/07/2010 10:49 am
Buy a tool to remove your BB - then you'll have it for next time too and can change it yourself.
As others have said - remove cranks and BB. Clean, regrease, tighten everything and usually creaking goes away.
Posted : 02/07/2010 11:06 am
lol martin ive posted a few threads about my creaking noise on here, mine still creaks and ive taken my bb out greased it cleaned it etc still there, thats why i said earlier i might just buy a new one like u say, it only happens when im in a high gear or pressure is on the bike
Posted : 02/07/2010 11:21 am
bit of rain sorted mine the last time is started creaking... over a month ago, must think about cleaning it over.
Posted : 02/07/2010 11:27 am
