crankset stuck help...
[Closed] crankset stuck help! >=0
 taka
1st off how do you get them fekers with the wrighting off!? [img] [/img] is it one of thease that you use? [img] [/img]?????????
and how do i get a stuck bolt one of thease ones [img] [/img]
after me being lazy and cheap not spending another £15 on the proper tool using my sqr taper one with a bolt
Posted : 27/07/2009 3:48 pm
 taka
bottom bid dosnt make sense i have got the bolt stuck in the crankset after removing the stupid locknutringthingi and trying to use my square taper crank puller on octalink cranks? ithink? shimano xt ones
Posted : 27/07/2009 3:51 pm
Those are self extracting crank bolts I think. You leave the ring in and loosening the allan bolt pushes against the ring and pulls the crank off.
If you have jammed a bolt in the hollow axle then remove the other side and hit it thru with a long drift.
Posted : 27/07/2009 3:59 pm
