Cranks - XT vs Zee ...
[Closed] Cranks - XT vs Zee plus running single ring
Eyeing up cranks for my forthcoming Rocket build. Want to run a single ring and probably a taco style chain device.
Zee looks good on price and comes with a single ring. XT a bit pricier and only come as double or triple yes?
If I wanted to run XT as a single, would I need to convert from the double or triple?
What's Zee like on weight and strength?
Any other crank options for this type of set up I should look at around the XT price point?
Posted : 11/06/2013 7:28 pm
No-one?
Posted : 12/06/2013 4:48 pm
I thought the zee was meant to be good but monster heavy...
Posted : 12/06/2013 4:52 pm
For the XT, get a triple and use the middle position with either a set of shorter chainring bolts (as you'll have no outside ring) or a bashguard in place of the big ring. Also get a "singlespeed" style ring, ie one designed to retain the chain, not with ramps intended to throw it off.
Don't know nuffink about 'Zee'.
Posted : 12/06/2013 4:53 pm
Zee crank arms weight 750g (the same as Saints), XT 600g. Strength between them is debatable. I went for the Zees on price; £80 including BB and chainring is hard to pass up. Be aware that Zees can't take a granny ring if you decide to go back to 2x10.
Posted : 12/06/2013 5:16 pm
Zee arms aren't hollow, they're indented at the back - cheaper construction than the XT. Strength/stiffness is up for debate.
Posted : 12/06/2013 5:39 pm
SLX?
The weight difference between XT and SLX M670 cranks is tiny if you remove the standard chainrings and will be about £35 cheaper. They were £92 for a 175mm triple at Merlin last week. In the longer term I also think they look better.
Posted : 12/06/2013 5:47 pm
Oh an XT double you can't fit a 32t ring in the 104pcd position as the chain will foul the tabs
Posted : 12/06/2013 6:15 pm
Thanks everyone so far.
lornholio - after 12 years running 1 x whatever don't think I'm going to worry about the ability to run a granny.
remoterob - looked at SLX, but I'm really shallow and want black cranks - guess I'll need some heli tape...
steve_b77 - any idea whether a 34T would run on there OK?
Posted : 12/06/2013 6:26 pm
"Oh an XT double you can't fit a 32t ring in the 104pcd position as the chain will foul the tabs"
Oh bollocks, does a 34t work?
Posted : 12/06/2013 6:34 pm
Mine was fine.
Posted : 12/06/2013 6:50 pm
I'd like to know about chainring compatibility too.
If I got a new style XT triple chainset, I'd surely be able to replace the 3 rings with a 32t single and full bash ring? Right?
I'm also averse to silver SLX on account of being a tart...
ive got a 32T on my XT double (its a hope chainring tho if that makes any difference)
Posted : 12/06/2013 6:52 pm
I had a 32T on my XT double & it did foul very slightly, but seemed to run ok.
Currently running a 34T, which doesn't foul at all.
Posted : 12/06/2013 6:57 pm
32t will be fine in the middle position of the triple XT
Neither Zee nor black XT will stay black very long, finish disappears really fast with heel rub
Posted : 12/06/2013 6:59 pm
As honourablegeorge has said, the finish doesn't last too long, i've got the Saints and as you can see after a few hundred miles the black starts to wear off: [URL= http://i48.photobucket.com/albums/f229/PSi3/null_zpsdc342367.jp g" target="_blank">http://i48.photobucket.com/albums/f229/PSi3/null_zpsdc342367.jp g"/> [/IMG][/URL]
I'm also running a 34T Renthal ring up front.
Posted : 12/06/2013 8:04 pm
I now have Zee cranks on my Soul - I was offended by the price I'd be paying for an unused BB and chain rings with other Shimano choices so thought I'd give them a go. From what I can see they're basically Deore arms with a stiffer stronger axle and 1x only. They are far stiffer than the Truvativ Stylo I had before (originally off my Boardman HT Pro 2010), to a shocking degree. I didn't expect to notice any difference, especially on a relatively skinny steel frame, but it was blindingly obvious just sprinting up and down my road, and again on the trails last night (again, on the sprinty bits).
I don't know how heavy they are but my gnarlified Soul is now up to 26.8lbs, from 26.5lbs, and since then it's also gained a steel 10mm thru-axle, a UST rear tyre and the transmission's gone Saint/Zee with Works XXI-style 34t and XT cassette from X9 with Hope 32t and SLX cassette.
Posted : 12/06/2013 9:58 pm
The Zee are pretty much Deore but with reinforced pedal inserts, no holes for the granny ring and a much more expensive looking finish (and possibly shot peened for better fatigue).
Unless you know you need the extra strength I'd be tempted to buy a set of 10 speed Deore cranks from Rose and sell the rings (as they are the same as 10 speed SLX) and buy a new middle ring.
Posted : 13/06/2013 1:08 am
