Cranks for 1x...
[Closed] Cranks for 1x...
General question, taking an older bike 1x and trying to keep cost down rather than the usual parts fest.
Is there a huge difference between reusing an old double (675) with a ring on the outer and a proper 1x crank like a direct mount, from a view of chain running?
Posted : 20/12/2017 11:00 pm
Just different chain lines I believe. I converted a 2x10 into a 1x10 with a double SRAM S1000 crank. Worked ok until someone put the rear mech in the rear wheel. So in the end we upgraded to 1x11 with a 1x crank and I think it just works that little bit better.
Posted : 20/12/2017 11:33 pm
 pdw
You'll want to space the chainring in a bit. Chainline will be around 52mm whereas cassette is centred on about 44mm. See [url] https://int.oneupcomponents.com/pages/understanding-chainline-for-optimal-1x-conversions-boost-and-non-boost [/url].
Posted : 21/12/2017 12:26 am
Ta! I was just wondering out loud, I’ve run triples as singles in the past but never used a double that way and wondered if the ring might end up too far out. Just wondering out loud really while considering whether to buy a ring or go the whole hog. I’ll give it a go I think.
Posted : 21/12/2017 12:31 am
I'd space it in but it'll work without it, the difference in chainline really isn't that much
Direct mount's an advantage in that you can fit a small ring mind.
Posted : 21/12/2017 1:53 am
