Cracking sound from...
[Closed] Cracking sound from BB
Took out the HT for the first time since the end of the properly bad weather (i.e. April) and the BB is making a strange cracking noise. Likely to be fixed by a regrease or is it a bin & replace?
Posted : 08/08/2010 5:40 pm
my bike does this, could be the bearings wearing ? try that or get a new bb or check ur chain ring bolts ive heard that can be a problem of this noise also, happens when pedaling hard ?
Posted : 08/08/2010 6:18 pm
Yeah, usually when there's some pressure (mostly uphill rather than spinning along the flat). Pretty sure most stuff is tight but I'll try everything again.
Posted : 08/08/2010 6:23 pm
yeh happens on my bike if your in a high gear and ur trying to climb " not that i do climb in a high gear" but it tends to happen, try take ur bb out and grease bearings, and replace, if problem occurs try new ones
Posted : 08/08/2010 6:24 pm
Bearings might be breaking up. Is there any play if you grab the cranks and try to move from side to side ? If there's play then the BB is shagged.
Posted : 08/08/2010 6:28 pm
Doesn't seem to be any play. If there was I'd have thrown the lot but it's just the noise...
Posted : 08/08/2010 6:33 pm
aye no play on mine just the god dam noise, put your bike in a padded cell ๐Ÿ™‚
Posted : 08/08/2010 6:34 pm
Well, I was expecting a shagged BB after a winter of wet, sandy and muddy riding because it's a raceface xtype :/
Posted : 08/08/2010 6:35 pm
mines a hope ceramic ive had it for about 2 year though so its not done so bad especially through the weather we have had etc
Posted : 08/08/2010 6:38 pm
Has the crank/spline interface dried up? Suggest removing cranks, cleaning & reasembling using a smear of copaslip.
FWIW my old Shimano XT octalinks creaked from new, but they were a bit notorious for doing that.
Posted : 08/08/2010 7:10 pm
 IA
Another classic cause is one slack chainring bolt, does it happen in all rings? try loosening and retightening them, it'll only take you a minute and might sort it.
Posted : 08/08/2010 7:30 pm
