Crack or sticker?
Crack or sticker?
Just spotted this, penny tap and there is no change in pitch, but ..
Any hints what to do?
It's an old Ridley X-Night, quite new to me, but sold in good faith and owes me very little.
Posted : 16/07/2023 9:34 pm
I’d ride it.
Stress the frame and see if there’s any movement. If not stick some resin +/- pigment in there, depending on how worried you are by how it looks.
Posted : 16/07/2023 9:37 pm
I vote crack. Take the wheel out and gently flex the chain stays together...
Posted : 16/07/2023 9:38 pm
oldnick, thols2 and AdamT reacted
Crack
Posted : 16/07/2023 9:39 pm
It's definitely a crack, the only question is, what's it a crack in? Could just be the paint, could be the whole thing. I'd check my medical insurance and then ride it
Posted : 16/07/2023 9:43 pm
I will try the wheel out and flex the stays to see if it visible opens. Marked with a sharpie the ends of it and will monitor. Just spent £600 at dentist this week, I am not looking for a WCA future post.
Any reason not to sand back to the carbon and have a look? Got epoxy and white pigment.
Posted : 16/07/2023 9:46 pm
+1 Crack by the look of it - irregular, jaggy shape shows it’s growing slowly but might suddenly go. This area of a frame is usually overbuilt as you’ve got a sleeve joint between the chainstay and BB shell, so unlikely to flex in normal use which probably rules out a paint crack. You could attempt a DIY repair .
Posted : 16/07/2023 9:52 pm
 csb
I'd sand back and check.
Posted : 16/07/2023 10:01 pm
Houns and thols2 reacted
You’ll need more than epoxy to repair as the crack indicates movement and broken fibres - over time the stress get distributed between fewer and fewer fibres and so will accelerate. A repair will need to reinforce the joint with an extra few layers of carbon. Easy Composites sell repair kits. No doubt plenty of how to videos on YouTube.
Posted : 16/07/2023 10:16 pm
Easy composites kit ordered.
Posted : 17/07/2023 4:55 am
oldnick reacted
Bonded joint failing .
Possibly due to a void in the joint/ not enough glue in manufacture.
examples of bonded joints
https://www.youtube.com/watch?v=6FYAUa9gzJM
Posted : 17/07/2023 10:06 am
jameso reacted
