So I have a Rocket with the Db air IL, I've got the app on my phone so I have the base tune. I've got a ride planned for setting it up tomorrow. I was idly wondering whether anyone has the same and could share their final setup? Bearing in mind I'm a little portlier than I'd like at 13 and 1/2 stone . I also have a mini dh next weekend and I'd rather not be setting it up during my race run
Open up lsc and hsc. Turn hsr all the way in then do the kerb test to set a basic lsr setting.
From there adjust the lsc according to the app. Hsc probably not too much of an issue but again just follow the app
I'd probably stick a few of the volume reducers in as well.
I've got 2 reducers in ( as per base tune) will give it a try today, cheers
Hi
I have a 26 Rocket with a CCDB in-line and it’s set exactly as per the details on the Cane Creek website.
Never found the need to change it.
I’m also in the region of 14 stone ish
Steve
Did you find the geek section of Cotic's website ?
http://www.cotic.co.uk/geek/page/DoubleBarrelTune
You're not too different to Cy's weight so start with the base tune.
I'll give that a look, put my neck out this morning so no testing for me.
I'm running the base tune that came on the card on my Rocket Max. It's very good as base tunes go run on the lower end of their recommended sag so I think that's 15mm.
