correct chain lengt...
[Closed] correct chain length
switching from a triple 22, 32, 44t set up to a double 22, 36t, how do i determine the new proper chain length as i assume the big/big system wont be applicable here?
Posted : 29/08/2009 11:29 am
 Hal
Check this link, http://bicycletutor.com/ you will find all you need. 8)
Posted : 29/08/2009 11:39 am
4 links (inner + outer + 1 link)
Posted : 29/08/2009 12:09 pm
why wouldn't the big big plus a pair for the rear mech work just because you're using a double?
Posted : 29/08/2009 2:30 pm
i am with onzadog.
big big plus a pair should still work.
Posted : 29/08/2009 2:36 pm
the big big method will make the same combination un-useable when riding as the rear mech will be too stretched out.
the big big will be like middle big on a triple which i tend to use quite a lot, maybe i shouldnt?
Posted : 29/08/2009 11:22 pm
big / big plus two links works for me with 22 / 36 bash. You can ride in big / big no problem
Posted : 29/08/2009 11:32 pm
yea thats what i set it to. may need to swap the long cage mech for a medium though
Posted : 29/08/2009 11:46 pm
