From 9 speed.
Chain and cassette are worn and I fancy a clutch mech. I've already got a 10 speed rear shifter in the spares box.
Guessing I will need : -
Chain
Cassette
Clutch mech
Will I get away with using the 9 speed chainrings ?
Which Shimano rear clutch mech is recommended ?
How do I know if I'm on a medium or long cage rear mech ?
Thanks
Zee or xt mech.. Pretty sure the chain rings will be fine
9 speed chainrings fine
Up to you which mech, they are all quite cheap.
Theory to me is triple = Long, Double = medium , single without extender= short. Extender can use short or medium cages.
Cheers Guys.
Will the chain length be the same ?
Thanks
Assuming the largest cog on the cassette is the same - yes.
