ok so my nite rider flight hid light has died. Water got in and has corroded the circuit board.
What kit could i use to convert them to led?
The batterys a 15v li-on.
Posted : 13/10/2010 6:07 pm
What size is the lamp you are replacing? Check out the cutter kits. Probably do triple xpg buck kit more light than your HId same battery life
http://www.cutter.com.au/proddetail.php?prod=cut757
Plenty of other kit out there - look to the recent threads for more - lumicycle convesion was one IIRC
Posted : 13/10/2010 6:17 pm
