Hi all,
As above thinking of changing to a 2 x 10 setup with a 26 and 39. But I can't seem to find anywhere selling the SRAM chainrings. Thought I'd see if I can just change the granny for the 26 and the middle for the 39 and remove the large ring and get the SRAM bash. Has anyone done this already and if so where did the parts come from.
Simon
Bump
I guess no one has thought of doing this then.
Simon
Thanks scapegoat. I'll haves look at that, I was hoping to keep it all SRAM if I can
I have been considering doing this to my Nerve XC (SRAM X0) but have no useful information to give you unfortunately. I came into this thread hoping there would be some ๐
Not at home at the mo so can not check but sure there is a short article about changing from 3x9/10 to 2x10 in July's MBR magazine. will have to check later.
Kevj,
Don't mind a dIfferent make of chain ring just wanted to try and keep my crank at the mo. I know SRAM do he chainrings just can't find them anywhere.
Let me see if ive got this right...you are currently running a 3 ring set up and want to switch to 2?
Theres 2 ways you can do this.
First one is you can buy aftermarket chainring (ta do some nice ones), however you may have chainstay clearance probs running such a big granny ring. But you may be lucky, unfortunately its going to be one of those suck it and see moments. Unfortunately sram dont make chainrings to fit your cranks that have the ratios you want. A standard 3 ring crank runs pcds of 64 & 104, where as srams double cranks run about an 88mm pcd so they wont fit. This leads me on to the second suggestion...
Simpliest way round this is to sell your current crankset and buy a specific 2 ring set up. Unless you go for a stupidly expensive set of cranks you should be more in pocket than what you would have been buying new chainrings (if you take away what you sell your current ones for). You shouldnt need to chain your front mech, only adjest the limit screws. I run a 970 xtr (3-speed) front mech on a specific double rng set up (not converted from a 3 ring) so i know it can be done and works.
Well i hope that helps ๐
Thanks cruzer,
Looks like i'll bite the bullet and get a specific 2 ring set up. I need a new BB also so my be a cheaper way to get what I wont anyway.
Thanks
Simon
Is removing the large chain ring and replacing it with a bash guard and just adjusting the limit screws considered silly? I never use the large ring and I have broken a couple of teeth on it so its a bit annoying.
SRAM X0 22-33-44 is it even possible?
