Converting a Shiman...
[Closed] Converting a Shimano rear hub to bolt-up ?
Anoyone know where I can get a good quality bolt-up axle to replace the std Shimano QR type ? Seem to have a problem with it slipping on the sliding drop-outs on my SS. Even with a chain-tug. Skewer actually snapped today.
Posted : 04/10/2010 12:17 am
m10x1.0 threaded bar. It should match the threads of most shimano rear hub bits.. just cut it to need.
Posted : 04/10/2010 12:28 am
hahaha... i used a threaded bar once and it snapped on me as i was tightening it up. you can't get enough torque using the little m10 nuts to reasonably hold the wheel in place.
i won't go into details, butt it was a right pain in the proverbial to remove the wheel from the frame and then the (bent) threaded bar from the hub.
Posted : 04/10/2010 1:12 am
 GW
just get a threaded cromo axle from your LBS for a fiver
Posted : 04/10/2010 1:26 am
Sure velosolo.co.uk do a conversion to nuts for shimano hubs...
.. and how did you manage to pull your wheel over with chain tugs on??
whats the set up??
Posted : 04/10/2010 7:01 am
I'd get a bike specific axle for strength and avoiding corrosion.
No matter what alpin says should work fine.
Posted : 04/10/2010 7:09 am
Halo hex skewers.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=26621 ]here[/url]
Posted : 04/10/2010 7:23 am
Raleigh do a good cr-mo axle for a few quid, complete with spacers and cone nuts.
Posted : 04/10/2010 7:59 am
