Possible?
Anyone do a suitable adapter?
Would need to screw into the frame on the Maxle side to reduce it to 10mm hole and then run a 10mm x 150 axle I guess.
Long shot I presume.
If not, can anyone recommend a 'cost effective' rear hub? Need to ride this frame at the weekend, so a rapid wheel- build could be on the cards.
Posted : 03/04/2011 7:58 pm
Only way of doing it is to buy a new rear wheel.
Even if you managed to spacer the axle out, the disc would be too far away from the caliper, and so could the cassette, meaning no brakes, and no gears!
Posted : 03/04/2011 8:04 pm
