whyte e120 quad lin...
[Closed] whyte e120 quad link what grease
 deca
[#2626945]
hi im am after the correct grease type that does not effect carbon or bushes
Posted : 03/04/2011 7:43 pm
 mjp
When I was a Whyte dealer I'm pretty sure it was called something like molycoat. Evil stuff. Sticks to everything (hands, clothes etc. but it stoped the creaks and lasts well.
Ask Chevin, they had it - or can tell you what it actually is.
Matthew
Posted : 03/04/2011 8:27 pm
 deca
thanks for that
Posted : 03/04/2011 8:52 pm
6.2.3: REASSEMBLY OF QUAD-LINKS
Tools required: Molykote Silicon 111
Before re-assembling the Middle Shield Washer Components (2 see Fig.8), apply a good quantity of Molykote 111 Silicon on top of the KP5AX Bearings. The Molykote Silicon should completely cover each bearing and be applied on both sides of each bearing as it is assem- bled into the Link Body. Next assemble the Shield Washer Components (2 see Fig.8), If you have applied enough Molykote 111 Silicon, it should spread from under the Shield Washer component as they are positioned. Wipe this excess Silicon away from around the Shield Washer Components.
(from the E120 manual page 21)
Posted : 03/04/2011 9:20 pm
 deca
nice one 4 that
Posted : 03/04/2011 9:34 pm
