Convert float to va...
[Closed] Convert float to vanilla: forks
 jonk
Can i convert my 140mm float to a vanilla by changing the spring pushrod, adding a spring and preload cap?
thanks
Posted : 12/05/2010 5:37 pm
 nbt
I swapped the internals on my old vanillas to the stanchions / sliders from an old pair of floats. as long as the things you put into the floats are the same as would go into vanillas, it will work fine
Posted : 12/05/2010 5:45 pm
