Hi Chaps,
I'm after a compression base layer / long sleeve top, I'd love to buy a Skins or a 2XU.. but they are expensive.
Has anyone bought a cheaper alternative that is actually just as good, or is the price fully justified for the tops?
I've got a Skins bib, which I can see the benefit of the cost for - as the padding an fit is very good indeed.
Ricks
just wear your girlfriends/sisters underwear
I was thinking a large area of compression... not just the nadgers.
http://www.maxgear.co.uk/CompressionClothing/index.html
Have used them for 6 mths and just as good as my skinz tops.
Try the discount code MAXRT10 for a 10% discount on checkout, not sure of it still works as it was sent to me last year.
Decathlon's own version is perfectly OK and, as ever, quite cheap. You can also occasionally pick up some of the UnderArmour stuff cheaply in JJB Sports.
Ricks, on the case ๐
im sure lidl are doing the compression base layers and aldi had them,never used them though....
