Coil converted Rev ...
[Closed] Coil converted Rev Teams with Sektor 140mm coil- alltravel spacer?
Just put together my coily Revs for the first time... All went according to plan, except that the rebound damper in the donor fork had a 10mm all travel spacer in it. I used a 140mm travel spring from loco but the fork's ended up at 150mm (with preload would all the way off etc)
So I'm thinking that the sektor takes its height setting not from the spring but from the damper? And obviously the chassis is for 150mm. Probably in use, it's going to sag in as if it were a 140mm fork but I was wondering if I should do something about this travel spacer... Any thoughts?
I'm used to air rockshox where all the height comes from the air assembly.
Posted : 06/06/2015 6:11 pm
