Coil Conversion for...
[Closed] Coil Conversion for the Pike
I take it this is the top-out video you were talking about?
That does sound properly harsh!
Posted : 20/11/2016 10:10 am
It does move through a guide. The photo above is from a coil RS Sektor and the baseplate that is used is the bit that looks like a seal head . CRConceptions photo shows a very similar setup for the baseplate (seal head replacement) - in the bottom photo its the largest plastic part, with the far end of the shaft being the seat for the spring
The Sektor has a top-out spring on the damper side of the fork.
Posted : 20/11/2016 10:35 am
Converted Sektor, MoCo needs the spring adding same as the Revs I converted
Posted : 20/11/2016 10:46 am
Yeah, I might wait for the SAR Spring kit or the TF Tuned one.
Oh, there is this as well
http://www.fahrrad-fahrwerk.de/awk/
CRConception look like they offer a modification to the Pikes negative airspring as well, if you click on one of the diagrams of their dampers - it shows a diagram with modified solo air spring curves.
How hard do you reckon it would be to increase the negative spring size, to offset the extra seal involved with the AWK system?
Posted : 20/11/2016 12:47 pm
There used to be a company in Germany that offered custom spring assays, that looked like they increased the Pikes negative air volume. I cant for the life of me remember their name though.
Posted : 20/11/2016 1:17 pm
There's the top out spring.
It looks like they were running the rebound completely open in that video, I think even my current forks will do that if I ran the rebound fully open.
Posted : 20/11/2016 1:41 pm
That's a win! Cleverly hidden too. Looking forward to hearin how you get on
Posted : 20/11/2016 7:22 pm
Coil spring assay on order from the very helpful Richard at CRConception 🙂
Overpaid on paybal by not selecting euros. Richard refunded me within minutes, slightly losing out a bit on his side - nice bloke.
Posted : 28/11/2016 4:40 pm
when do you expect to have it in your hands? Any idea if he do you know if he covers the various different travel options?
Posted : 28/11/2016 4:46 pm
Yeah he will quote you for international delivery, not sure who the courier is - but I paid via paypal so it is insured. Not sure on delivery times.
Based on my dealings with him, I trust him so Im not going to pester what appears to be a very "avalanche suspension" crazy engineer in a shed kind of company 🙂 I mean that in a good way, Richard is very nice.
Posted : 28/11/2016 5:08 pm
dirtydog - Member
Hmmm
postive or negative "hhmm"? Seems like a cheap upgrade, still going to wait for coil though
Posted : 28/11/2016 8:44 pm
Neither really, just came across it, just another option, promises coil like performance 😕
Posted : 28/11/2016 8:58 pm
It does increase the negative...
Posted : 28/11/2016 9:39 pm
"Promises coil like performance" why not just get a coil then? More performance (faster reaction times from compression to rebound stage) and none of the hassle.
Oh and that vorsprung thing won't do what it says on the tin, it will make the fork more sensitive but unless it is a triple chamber air design like the Manitou IRT, Ohlins forks, air motocross forks or the AWK Pike kit - it won't give the same midstroke support as a coil.
If it works with the ARK Pike Dual main chamber system then it might be cool.
Looks like that kit would work with the AWK kit, I'd suggest that if you prefer resale value or lighter weights - go with a combination of that kit with the AWK Lyrik or Pike dual chamber system.
If you don't mind extra weight, with the coil - you have three less seals than the above modification, better performance (quicker reaction times, more sensitive and less prone to the spring binding under load - would be a guess) and better reliability.
Posted : 28/11/2016 10:21 pm
These coil conversions look very interesting. Who has a success story?
Posted : 28/11/2016 10:24 pm
Coil conversion kit arrived from France yesterday, installed it today.
Initial impressions:
* The coil itself is much better finished/made than original rock shox coils of old - everything else is functional.
* Installation is pretty easy and straight forward, a little bit of common sense is required.
* It's much, much more sensitive than a standard Pike now - under normal garage bounces - it feels considerably more sensitive. However the real difference is when you apply a fair amount of torsional loading to the fork whilst compressing it through it's travel, the solo air spring used to seize up and cause the fork to go very very sticky - this doesn't at all. I was quite shocked by that. It's also a noticably more sensitive than my fathers Lyrik RCT3 as well.
* A quick car park bounce around confirms that I got the exact sag that I asked for of 21 percent (I asked for anything between 20 and 22.5 percent but preferably 21). It feels a lot more lively when hopping around, it doesn't feel dead because it's a coil - in fact the fork feels livlier and more playful than before. Resistance to brake dive is improved, not massively but moderately - the fact that the fork is a lot more sensitive will allow me to considerably increase the low speed damping on the FAST damper as well.
* The fork has only gained 200g :mrgreen: less if I install a stealth maxle. This means it's about the same weight as a Lyrik, 34mm forks like the Bos and Mattoc and it's lighter than other 35mm forks like the DVO Diamond. 🙂 Anyone who says that coils carry a massive weight penalty is having a laugh.
* I put a kink in the low friction plastic wrap that protects the inside of the stanchion, so theres a very slight clicking noise as the coil moves over it. I'll order another from Richard next week and replace it.
Overall, I'm very impressed and highly recommend it to anyone who is on the fence.
Posted : 03/12/2016 7:39 pm
Tom, any further thoughts on the coil conversion?
Posted : 17/12/2016 8:53 pm
Anything more to add Tom? TF don't look like they're going to be doing anything this month so considering going continental
Posted : 10/01/2017 12:19 am
Still loving it, further ridings just confirmed what I already think.
The fork doesn't pack down, but I suspect that it would be even better with a slight rebound shimstack tune to suit the more linear coil but I can't actually feel anything wrong with it - but I'm keen to try just to see. So I'll try that in the new year - the new found sensitivity of the fork has highlighted a few minor niggles in the custom damper tune, I think the first high speed shim could just be a little lighter so when I set the HSC to 10 clicks from fully open instead of 5-7, I get the improved support but with a bit more small bump sesnitivity. I lose a tiny bit of grip in braking bump ridden berms when going full tilt..... it gives me a feeling like the forks going to tuck under, which I never noticed with the airspring when I set HSC to 10 clicks - because the grip wasn't as good in the first place....even with less clicks. Its kind of like listening to an MP3 at 128kbs vs 320 (something) kbs, the airpsring just kind of muddied the feedback a bit.
Posted : 10/01/2017 12:36 am
I have been watching this thread and very interested in making this conversion, but have a few queries.
My pikes are the 650b version set at 140mm.
Is it quite simple to convert the forks? And is it possible to reduce the travel (via the spring ordered) to say 130mm?
I just fancy this conversion to get away from any air spring maintenance really, I weigh 85kgs with my riding gear on, the spring being total rider weight compatible.
Any help appreciated.
Posted : 15/01/2017 1:22 pm
 Neb
Are these all the options for coil conversion?
CRConception
TF tuned
SA Racing
DIY using lyrik bits, everything fits bar the spring
I read somewhere that someone used a marzocchi 350 ti 160mm spring with the lyrik bits. Whixh meant no cutting. Any idea where would be best to source the bits / spring?
PS, for a DP pikr
Posted : 16/01/2017 6:48 pm
After reading and watching this thread, I am about to buy the coil conversion kit.
Will probably use the existing air set up through the remainder of the winter months, as the fork is working fine.
Once the spring arrives and the fork needs a service I will make the conversion to the coil set up.
Looks to be a much easier and less faff set up in terms of usability and maintenance.
Posted : 17/01/2017 9:45 pm
The conversion for the CR Conception kit is a breeze if you can do a lower fork service.
I could see the DIY spring conversions as being a bit of a headache.
Honestly, I'd install it as soon as you get it. Winter is when you will reap the most benefits from the extra traction.
I'm fairly certain CR Conception do a 140mm length spring, but I'm sure if you ask nicely he will cut you one to size. The guy has all the tools and kit at hand to do this.
I love the kit, I like the midstroke support of air forks and air shocks with lots of tokens - but on enduro bikes I think these progressive setups are too harsh for all day riding and long descents. Progressive setups are great if you're riding balls out down a 5 minute DH run, I don't think this is ideal for Enduro though. What the coil spring modification does is give you a nice spportive feel in the first 60 percent of travel, yet on big hits it will use more of it's travel - you get chassis stability with a bit more square edge comfort and small bump traction.
Posted : 17/01/2017 10:49 pm
 Neb
I'm thinking of at least waiting until SA Racing get their kit to market, hopefully TF Tuned won't be far behind. CR Conception sound good to deal with, but I've had cracking service from TF in the past and I'm happy to deal with them.
Posted : 17/01/2017 10:51 pm
I'm sure TF tuned would service a Pike with the CR Conception coil in it - there isn't really anything that could go wrong.
I'd have bought the kit a year ago had I tried one, but I was on the fence as well - considering the shit I went through with my Pikes I wish I had!
Posted : 17/01/2017 10:57 pm
 Neb
Was the ordering process with CRC ok? I wasn't quite sure whether I'd actually end up with what I wanted! Did you need to give any extra details over your weight and model of fork?
Posted : 17/01/2017 11:07 pm
I gave him my riding weight, the rough amount of sag that I would be happy with, the fact that I rode flats (as I know this can affect what spring rate you should run to a small degree and the wheel size and travel of the fork.
Sure, he doesn't speak much English but google translate was enough to convey the right information - not only did I get the rough amount of sag that I was looking for, I got the exact right amount of sag that I wanted. Although I can't say whether you would - all I would say is that he will be as good as anyone else at getting the closest spring rates for you and possibly better as he offers 10 spring rates as opposed to the usual five or six.
The ordering process was simply a matter of emailing him the details of what I wanted, then paypaling him - the spring turned up four days later.
Posted : 18/01/2017 12:35 am
Tom, with the crc kit can you wind any preload in or is the sag only changed with a different Spring?
Posted : 18/01/2017 12:58 am
Ordering from CR is made very easy with emailing Richard.
Very helpful guy, walked me through everything and is supplying a 140mm spring. Basically it looks like they will supply most things to match the customer requirements.
A few questions back and forth, but always very quick with the responses .
Looking forward to fitting it now, might very well just fit it once it arrives.
I felt the same about the tokens, took all of them out, I'm no hero of a downhiller, just want a coil fork of old really.
Posted : 18/01/2017 9:23 am
No preload adjustment but it would probably be quite easy to retrofit one from an older rock shox fork - or a boxxer?
Posted : 18/01/2017 10:37 am
You could also probably get some machined or even possibly chop a bottomless token down to increase the preload.
Posted : 18/01/2017 11:15 am
Tom_W1987 - Member
yeah you would expect 35mm Boxxer preload discs to be an easy option or, at the very most, need a little trim to fit the CRConception top cap and spring.
Think I need to give TF a call and see if they'll give an idea of how far away their kit really is. Otherwise I might have to speak some French very soon!
Posted : 18/01/2017 11:34 am
Tell you what, Ill buy the boxxer top cap and see if I can do it myself. Woulndt be hard to find a machinist to help me out.
Machining some spacers to adjust preload wouldnt be hard either.
Posted : 18/01/2017 11:54 am
Why would you want preload adjustment? To raise the ride height?
Yeah, but as you imply - preload isnt that useful as it doesnt alter the spring rate.
Posted : 18/01/2017 11:55 am
As long as a preload spacer sits nicely on top of the spring I wouldn't be too concerned about the top cap. I changed an old 32mm Boxxer from air to coil and just dremeled off a chunk of the air cap then used a standard preload spacer, worked grand for years
Posted : 18/01/2017 12:05 pm
 Neb
Legend - If you hear back from TF Tuned can you post the reply? I'm in the same boat, tempted to buy CRC but keen to see what TF have coming out first.
Posted : 18/01/2017 5:14 pm
Will do, they're going to give me a call to discuss dates tomorrow so fingers crossed
Posted : 18/01/2017 5:39 pm
Well they didn't call, 1 more point to the Frenchman
Posted : 19/01/2017 7:55 pm
Shame there is no news from TF as this thread has got me very interested.
Anyone know if these coil conversions work in a dual position pike? I will probably ask the Frenchman but my french is limited.
Posted : 20/01/2017 11:22 am
Just asked for my dual position lyric and you need the solo air cap which is about 20 euros plus postage and then it will work.
Posted : 20/01/2017 11:36 am
Thanks Pridds
Posted : 20/01/2017 11:38 am
This is the part number 11.4018.012.010 UK shops dont sell it seperatley but some of the europeans one do .
http://www.mountainbikes.net/mtbikes/produkt.cfm?pnr=26491&ctry=1&za=1&lc=1&curcd=1&cid=B5931113-5056-B502-E51C75517AC359A5
Posted : 20/01/2017 11:48 am
I think Richard will supply you with a solo air cap if you wish.
Posted : 20/01/2017 1:42 pm
He's out of stock of them.
Posted : 20/01/2017 2:38 pm
Thanks again Pridds, I just ordered one from amazon uk with free delivery
Posted : 20/01/2017 2:45 pm
 Neb
I'm assuming an older lyrik or boxxer top cap will also fit? Although not sure if the depth is the same?
Posted : 20/01/2017 5:54 pm
Boxxer top cap won't fit as it's a different thread or pitch, apperently.
Posted : 20/01/2017 6:44 pm
I happened to speak to a technician at TFT today regarding my Pike which is sticking down. He recommended that I send it in immediately for a service so that they can investigate why it is sticking and suggested that if there was internal damage then one option was for them to fit a coil... only came across this thread just now so didn't ask any further questions but doubt that he would have mentioned this unless they could do the work immediately.
Posted : 20/01/2017 9:17 pm
Spoke to TF Tuned, very cagey answers again but it sounds like it going to be the better part of a couple of months from now. As riding time is likely to be at a premium for me this year, I've now emailed Richard at CRConception.
Now the real issues arise though........ 150 or 160mm?!
Posted : 23/01/2017 2:39 pm
Robin, they will sometimes knock one up using old lyrik spring assays - you only get about 5 spring rates to choose from though.
The new coil conversion from them will be a ground up design....
Legend....160mm
Posted : 23/01/2017 11:10 pm
It was credit card rollover today so I've ordered a spring from CRConception. Really looking forward to giving it a try, you should be on commission Tom 🙂
Posted : 23/01/2017 11:22 pm
Ordered mine too 🙂
160mm in the end, coz moar! Think I'll end up with a 64.5 degree Five at the end of this, most be close to a record...
Posted : 23/01/2017 11:25 pm
Looking fwd to seeing how this goes legend! Hopefully it arrives in time for Dunkeld this weekend (assuming you can make it)!!!
Posted : 23/01/2017 11:46 pm
My 140mm Spitfire is now at 64.1 deg, and that's with the fork shortened from 160 to 150mm. Just seems to work for how I ride, even on flat trails!
Posted : 24/01/2017 12:32 am
Thinking about this for my 2014 34's. They are not that plush compared to my 32's. While I'm at it would increase the travel to 150mm. Never tried a coil fork before.
Although I can't find out any information on their website.
Posted : 24/01/2017 3:24 pm
Don't think he does the kit you're after. Might be worth dropping him an email though
I now consider myself in a race against RB, but as I keep getting a " 😉 " at the end of every email I reckon I'm winning.....
Posted : 24/01/2017 3:49 pm
I have also had a 😉 at the end of every email.....but I've only had one email.
If it's a race you want I'd better start preparing since I want to put the coil in the DPA fork on my hardtail and swap it with the solo air on my FS. (I intend to do away with dual position which didn't turn out to be as useful as I thought even on a hardtail.)
Posted : 24/01/2017 3:54 pm
With someone like Richard at CRConception, if enough people show interest and email him a little petition asking for a 34 spring, I'm sure he'd knock one up. I think it would be worth a try!
Posted : 24/01/2017 9:01 pm
Anyone know if he's likely to send out a note when the kit is on its way?
Posted : 26/01/2017 3:03 pm
Just badger him a few times....he'll tell you when its posted. The coil turned up about 4 working days after I ordered.
No instructions in the kit btw, they are on the website.
Let me know how it goes.
Posted : 26/01/2017 3:06 pm
I saw the website instructions, doesn't look any more complicated than swapping an airshaft....hopefully all will be self explanatory
Posted : 26/01/2017 3:16 pm
Yeah, the clip is a bit of a ball ache in comparison to the big circlip used with plier holes on the air shaft model.
It requires a technique a little bit like seating a tyre. Hold one end of the clip, whilst pushing around in a circular motion until the whole clip snaps in.
Posted : 26/01/2017 3:19 pm
I assume you couldn't just use the snap-ring from the air shaft?
Posted : 26/01/2017 3:37 pm
You could try I guess, I used the one provided.
Posted : 26/01/2017 8:31 pm
Anyone recieve their coil kit, yet?
Posted : 28/01/2017 10:31 pm
From his email last night, they've all been posted today!
Posted : 28/01/2017 11:23 pm
I've not heard anything? Got my solo air cap etc all ready and waiting but wasn't going to hassle just yet.
Posted : 29/01/2017 12:21 am
yep, mine was posted today.
top man richard.
Posted : 29/01/2017 12:37 am
Rubber_Buccaneer - Member
I just dropped him a friendly email so I knew roughly when to expect it. iirc his words were "all the kits are leaving tomorrow" so I assume that includes yours!
Posted : 29/01/2017 1:53 am
Which kit have people ordered from crc? My French isn't particularly great and I'm wondering which option I should be choosing for a 170mm Lyrik. Is this the coil kit everybody is talking about:
There is also a file titled 2017 spring kit which is €135. Not sure what the difference is?
Thanks
Posted : 29/01/2017 12:19 pm
I have ordered a 2017 spring kit for a 160mm pike but they are also available for a 170mm lyric. What you linked to is a hydraulic cartridge.
I use the translator built into my browser to translate the site. It isn't perfect but helps. Other text I type into google translate. Download the order spreadsheet, it lists the options and has some English 'help' boxes
Posted : 29/01/2017 3:30 pm
2017 kit I believe refers to his current design rather than a fork. Up until fairly recently his design was a bit....... interesting!
Posted : 29/01/2017 3:51 pm
Yes, I hope I've understood correctly
2017 spring kit = coil replacement for air spring
Cartouche = replacement damper
Cartouche all in one = combined coil spring and damper
All I wanted was the coil spring Tom has been so pleased with, the damping cartridges are an unknown to me so I'd probably look somewhere more local for any upgrades/adjustment
Posted : 29/01/2017 4:29 pm
Very helpful. So the spring kit is basically just a coil on the air side and the charger damper in a lyrik/pike remains on the other side. I guess the competitor to the spring upgrade is a luftkappe, but a spring seems like an inviting option.
Posted : 29/01/2017 5:36 pm
First go out with the coil at Grenoside this weekend, baby head sized rocks on the Steel City DH were a fair bit more muted than before and the fork even felt livelier! It's not suddenly a new fork, but it's definitely an improvement as I suspected from other rides!
I couldn't push hard though as I totalled my ankle in December, tweaked it recently and now it seems unstable.
Posted : 30/01/2017 12:12 am
Just received my invoice with tracking details 🙂
01/30/2017 Pris en charge LORQUIN BP
Hope to be fitting it at the weekend 😀
Posted : 30/01/2017 5:11 pm
Pris en charge SARREBOURG PDC1
I'm sure there's a reason they're 10km away from each other 🙂
Posted : 30/01/2017 5:42 pm
Page 2 / 6
