Simple question, just coming back to the UK so a bit out of touch. Where is good to get them online
I get mine from Wiggle because I'm lazy
http://www.wiggle.co.uk/lifeline-lifeline-co2-tyre-inflator-cartridge-30-pack/
Out of interest, is a 16g canister big enough to get a 27.5 tyre fully inflated or will the 24g be better?
tyre inflators.co.uk is much cheaper than wiggle, I buy a box of 3016g cartridges
16g from tyre inflator work out so cheap, you can put two in for less than on 25g if you need to.
If you've a large volume 27.5 tyre then I doubt a single 16g canister will be enough, however I use mine as a quick way to get the tyre mostly inflated and use my manual pump to top it up. It's much easier to get to the right tyre pressure that way too. I have 29 inch wheels and a canister will get the tyre soft and a minute or two on my pump will get it upto the pressure I like.
16 aren't big enough for mtb. Go 25 or 30.
Those 3kg cartridges should do the job
You can get 88g cartridges that are used on airrifles..should be enough for 2 fatty tyres..
You'll need a 88 to 12g adaptor..
GaryM's bike, pictured earlier.
[url= https://c1.staticflickr.com/3/2842/34032029946_607977302c_b.jp g" target="_blank">https://c1.staticflickr.com/3/2842/34032029946_607977302c_b.jp g"/> [/img][/url][url= https://flic.kr/p/TRi3R1 ]Air bike[/url] by [url= https://www.flickr.com/photos/takisawa2/ ]pten2106[/url], on Flickr
Decathlon do 16grs at 99p each
Tyre inflators is a bit steep for postage. Not sure it really works out on balance
How often do you use them that you buy them in 30 packs?! I bought a box of 6 iirc about 5 years ago? I've got 2 left, and i used one on someone elses bike. Am i not getting enough punctures or can you do something else with them?
I do feel they are a bit of a wasteful extravagance, in terms of resources, as they are use once and throw away. In most cases a pump would do the same job but more slowly.
Always used www.co2cartridges.co.uk (same site as tyre inflators, just rebranded).
ali69er - Member
£4.99 on a box of 30 that costs £17.99, total £22.98. vs £26 at Wiggle. Though nice to see a big name retailer now doing big boxes and more reasonable prices.
pnik - Member
Seat tubeless tyres dead easy.
Though I've finally got the knack with a track pump and massive amount of soap suds, that I usually can do it without CO2, but occasionally I give up and use the cart.
I also use mine to fix other people's punctures (while advising them to go tubeless). Occasionally had a puncture that's taken the pressure down before sealing so re-inflate with one, and less frequently had to put a tube in so used them then.
Box of 30 will last me a long time, but I've used them all up over a couple of years, and they work out massively cheaper than LBS prices or online prices for just a few (which are in the £1+ per cartridge range. Though seen fancy branded ones in an LBS for over £10 a cart!).
Daily bike commuting, riding cx bike/road bike/mountain bike at weekends.
A box of 30 last me about 5 years but bulk buying is cheaper.
Aldi did an adapter and cartridges a while back plus refill pack seperate Bound to come around again or Lidl
