Clikky Fazua motor?
Clikky Fazua motor?
 FOG
[#13510612]
The Ride 50 in my gravel bike makes an annoying clicking sound when pedaling. It doesn't seem to affect the performance but is loud and irritating. It's only done a thousand miles or so but I have checked most obvious things . Motor bolts torqued correctly, crank arms tight, pedals brand new and tight on cranks, any other ideas for the cause?
Posted : 17/01/2025 2:00 pm
Chain ring on tight?
Tooth bent or missing on chain ring?
Pedal bearing worn out?
Posted : 17/01/2025 3:31 pm
Can't help with the cause. I had exactly the same and LBS (also Fazua service centre) fixed it for me and its been fine since. I realise this is unhelpful if you want to solve it yourself. Hope you get it fixed.
Posted : 17/01/2025 3:32 pm
