Clicking sc chamele...
[Closed] Clicking sc chameleon
There's an infernal clicking coming from my chameleon and it's getting right on my tits.
The eccentric bb has been stripped and re-greased,
the second possible trouble spot, the headset has been stripped and re-greased.
I went out on it today and the clicking is still there,
it clicks in time with pedal strokes, still does it when I stand up whilst pedaling so it's not the saddle post or rails.
Only thing left that I can think of is maybe the bottom bracket cups are on the way out?
It was a frame off of ebay but it's only 2 to 3 years old and still in good nick.
I'm running out of ideas stw collective please help.
And it's not my knees clicking btw
Cheers DH
Posted : 10/03/2012 11:53 pm
Mech hanger, qr skewer
Posted : 10/03/2012 11:55 pm
cheers, thats 2 ideas.
My plan is to give it a really good scub down and start checking top to bottom.
Posted : 11/03/2012 12:02 am
Sounds stupid, but have you made sure the excess front mech cable isn't getting knocked by the DS crank arm?
Had a lot of trouble getting my SC Cham BB to stop creaking though.
Is it a creak or a click?
BB, pedals? Can you get it to make the noise with the bike still and putting pressure on the pedals?
Posted : 11/03/2012 12:08 am
Tried the front mech cable realman, not that, wish it was that easy! ๐Ÿ˜•
It's definately a "tick tick tick" in time with the pedal strokes.
Maybe once or twice I've made it click with the bike still and pushing on the pedals, not enough to point straight there though ๐Ÿ˜
Posted : 11/03/2012 12:23 am
 Goz
What BB are you using ?
Posted : 11/03/2012 12:42 am
A shimano xt external m770
Posted : 11/03/2012 12:56 am
The thread on my EBB started to wear, once it was replaced it was quiet.
Also maybe get a cheap BB from Rose and try that?
Posted : 11/03/2012 1:26 am
I'd double, then triple check the EBB. I regreased mine several times and the clicking wouldn't go away but eventually an LBS found another part of it to grease and it finally stopped.
Posted : 11/03/2012 1:49 am
I've had this caper on a mates scc before. As for as the ebb is concerned, too much grease is nearly enough. Also look at chain ring bolts. However, if It's not the bb area, my money would be on the mech hanger.
Posted : 11/03/2012 9:08 am
Thanks again guys.
More things to try next week! ๐Ÿ™‚
Posted : 11/03/2012 10:16 am
Pedal threads are the first port of call, then chainring bolts, and sq taper crank bolts if present.
Posted : 11/03/2012 11:09 am
Had it on one bike, turned out to be bling alloy chainring bolts coming undone. Check em !
Posted : 11/03/2012 11:13 am
I have the exact same issue on a Rockrider frame. The frame has recently been changed due to warranty, still annoying click. Time for a strip down and grease up.
Last sentence not meant to sound like prison speak.
Posted : 11/03/2012 11:50 am
I had an annoying click on my singlespeed that only mannifested itself when pedalling. I stripped an greased everything and then eventually narrowed it down to the rear brake calliper.
It appeared that the when putting force through the drivetrain, something must have been catching on the rear brake which caused a metallic like click.
I took off the caliper , cleaned it, replaced the pads, centered it, and the click stopped.
It took me ages to find as I was convinced it was coming from the crank or seatpost area due to it only happening when I was pedalling.
Posted : 11/03/2012 12:07 pm
In my experience if it's definitely a 'tick' then it's going to be related to a rotating bearing - usually BB but could be a pedal axle.
Posted : 11/03/2012 12:08 pm
Pedal bearing.
Posted : 11/03/2012 1:07 pm
Cheers again everyone.
It's done the ticking with 2 different sets of pedals on,
Managed to get a pair of thinnies, which are fitted atm, so they're fairly new.
Reckon I'll check the bearings anyway!
Posted : 11/03/2012 1:55 pm
My Cham seems to develop a BB area click every 6 months or so. I full strip down of the EBB, including removal of the cups, regrease and reassembly seems to sort it. Im pretty thorough doing this now as the first time I tried I didnt get rid of the click. If Im meticulous about cleaning it all up it does actually sort it.
Posted : 11/03/2012 3:28 pm
