cleat engagement wi...
[Closed] cleat engagement with new boots
Having only ever used one set of spd boots and cleats, ( for about 8 years!!!!) I've taken the plunge and got some new winter boots.
I've taken time and set up the cleats to let my feet assume the same pedal position - ball over pedal axle; same spacing out from crank, same release points for cleats.
The old/new boots have very different sole shapes and sizes so it's not easy to copy one from the other, but the cleats appear to be in the same position.
I sometimes find I'm mashing around a little, then I engage the pedal. other times i'm straight in no problems. My right foot ( non leading ) is worse than my left. I can disengage easily and quickly, that's fine.
I think I've put it down to quite different types of sole.
Old boots a touch wider, flatter sole, rubber and more casual walking boot type ( old Lakes )
New boots slightly narrower sole, more 'plastic' type, a lot stiffer and they seem to have more curve around the ball of the foot ( rocker in bodyboarding terms! ) they're spesh Defrosters. I think it's that curve that is significant and definitely feels different - but quite comfy!
Also I suppose that I'm putting new cleats into an old pedal so that might have an effect too.
So..... do others find it takes a little time when moving from one boot to another?
Just never done it before....!
thanks all
Q
Posted : 23/10/2009 12:30 pm
Ultimately, I'd guess that your cleats have worn out. Grab a new set.
Posted : 23/10/2009 12:37 pm
as long as there's clearance all the way around the cleat you should be fine.
I took a stanley knife the sole of my Shimano winter boots as the 'tread' was too close to the cleats and made engagement difficult.
TM: sorry didn't explain - new cleats!
wwaswas: The cleat is tight to one tread, but so was the old pair! weill check it out. I presume if the tread is causing a problem, i'll see some form of marking on the tread. Good point!
Posted : 23/10/2009 12:47 pm
engage the shoe in the pedal whilst you're not wearing it - if you hold the shoe upside down you can see where contact is as you twist the shoe in the pedal to engage/disengage
Posted : 23/10/2009 12:48 pm
As wwaswas said, then perhaps clear some of the tread away from the cleat recess, might be fouling the pedal preventing proper engagement.
Posted : 23/10/2009 1:27 pm
i find that new cleats take a little wearing in to get a nice easy click in and out - might just be that?
Posted : 23/10/2009 1:36 pm
Just back from dinnertime sarnie.....
Had just the same thought - put the shoe on the pedal and see if it catches the tread!!
Great minds....
Matthewlhome: Yep, was wondering that too. My old setup is well bedded in, so as you say, it might just be that. Thanks for conformation and reassurance.
Have to dash out, but will play with pedals/shoes tonight.
thanks all
Q
Posted : 23/10/2009 1:49 pm
I've clipped the boots into the pedals - and doesn't it look odd!
The inner part of the spd pedal is touching the tread and leaving a metallic mark on the tread. Though the pedal's touching the tread i don't think it's preventing the cleat clipping in.
I suppose the thing to do is ride a few times, and if the new cleat hasn't worn in like mathew said, trim off a bit of the tread.
ok....think I'm there.
thanks all
cheers
Q
Posted : 23/10/2009 5:25 pm
