cleaning Ti
[Closed] cleaning Ti
[#2138626]
what's the best wat to get it looking good after muddy rides and a lot of use, any tips for a shiny looks like new frame?
Posted : 29/10/2010 2:01 pm
Just wash as you would any other bike and then use something like Mr Finish Line (or Mr Sheen) to make it shiny.
Posted : 29/10/2010 2:04 pm
 IanB
Sam sent some oil with my Pegasus that brings the frame up a real treat. I use normal soap and water to get off the usual grime, let it dry and then wipe over with cloth dabbed in the oil, then polish off with a clean rag. No idea what oil it is as it's in an unmarked bottle. Don't know what I'll do when I run out, but then you don't need much so will last me a while I expect 🙂
Posted : 29/10/2010 2:06 pm
Squeeze some fresh lemon juice into some water and wash it down after cleaning it gives it a nice finish
Posted : 29/10/2010 2:27 pm
Duraglit
Posted : 29/10/2010 2:28 pm
Once washed lightly spray with wd40 and wipe over. Job done! Or if you want a deep lasting shine ie removing any tarnish try Duraglit. WARNING!!! This will seriously buff to mirror finish and likely to be permenant so not advisable if you just want want a 'polish'.
Posted : 29/10/2010 2:31 pm
After a wash I use a hard wax polish. You can get these in Halfords etc for a few pounds
Posted : 29/10/2010 4:03 pm
Quick rub with 80 grit paper 😉
Posted : 29/10/2010 4:27 pm
 drew
I'd like to refurbish my omega ti road frame. Where can I buy 80 grit paper from?
Posted : 29/10/2010 11:45 pm
I rebrushed my titanium Litespeed frame with a Scothbrite pad, it came up as good as new.
Posted : 30/10/2010 1:50 am
All this depends on the finish; polished frames you can go hammer and tongs at with the duralit but matt finish frames I have always had success with a brillo pad.
Posted : 30/10/2010 8:18 am
