Cleaning inside for...
[Closed] Cleaning inside fork lower tube
7 Users
Just taken my Fox talas 32 fork apart for the first time (for me) and the left [Talas/air] side has got some moisture and muck inside the lower.
I'd like to clean this out before reassembly but unsure how to do it. Anybody have any ideas?
Posted : 21/01/2009 12:56 pm
Weak solution of degreaser and a bottle brush.
Posted : 21/01/2009 12:58 pm
 sv
IPA from local chemists (possibly) or Maplins in an aerosol or indeed the 'bay'.
Posted : 21/01/2009 1:00 pm
twohats: such as detergent or stronger?
Posted : 21/01/2009 1:01 pm
Quick update....... I used a shotgun barrel cleaning rod with workshop towels wrapped around the end. Lovely and clean now.
Posted : 22/01/2009 9:22 am
sharkbait, I read the first 4 words of your 'quick update' reply and thought 'that's a bit harsh' 😉
Posted : 22/01/2009 9:24 am
I've got a length of dowel with a cup hook (plastic coated) screwed in the end for this job, and then closed up with pliers to make an eye. You can then feed a kitchen cloth (ASDA value brand, less than a quid for 25) through the hook and wiggle and clean to your delight without worrying about what to do if the cloth gets detached.
Posted : 22/01/2009 10:42 am
@ theotherjonv: now you see I wouldn't have thought of that 😳 ........... cheap, simple and it works!
Posted : 22/01/2009 11:14 am
Bottle brush, fairy liquid and a kitchen sink. Gets the insides cleaner than you could ever imagine. Have to leave it to dry out for quite a while tho before reassembling - standing above a radiator is good for this. Gets rid of all the dirt and ever last drop of moisture.
Posted : 22/01/2009 11:54 am
I usually take molgrips method. But last time I used carb cleaner which was 99p from the local hardware store for a 500ml aerosol. Wont get rid of lumps of grit etc very well but gets the last of the oily muck out. Dnt smoke while doing it though 🙂
Posted : 22/01/2009 12:01 pm
