Chunkey Monkey - no...
[Closed] Chunkey Monkey - not tubeless compatible?
[#7652067]
Anyone else had problems getting chunky monkeys to stay inflated tubeless? Ive reseated the new 29er tyre twice now and pumped up to 40PSI but still seems to leak like a sieve around the bead.
Posted : 16/02/2016 7:17 pm
Ive run them tubeless and so has a friend of mine ?
Posted : 16/02/2016 7:19 pm
Possible then....thats good. Perhaps I just need to pump it and take it for a 20min spin to get the stans working.
Posted : 16/02/2016 7:21 pm
More tape!
My 29 CM works fine on superstar rims
Posted : 16/02/2016 7:24 pm
Had no problems with CM 29ers on 2 different rims. No sidewall leakage at all, a little bit around the bead and valve, but both sealed within 15/20 mins. Did need to pump them both upto 40 psi to get the 'pop' onto the rim.
Posted : 16/02/2016 7:25 pm
No problems here either.
Posted : 16/02/2016 7:28 pm
Not had this issue with the tyre you're using but have on others and Kimbers is right- more tape will solve this.
Posted : 16/02/2016 7:30 pm
My 26er CM worked better tubeless than the Ardent TR I ran with it!
Posted : 16/02/2016 7:37 pm
Work great for me on Sun Ringle EQ27 and Mavic 321 and 521. I run low pressures too, around 17psi.
Posted : 16/02/2016 8:03 pm
Works well on Flow Ex rims. Goes straight up with one wrap of stans tape and a track pump.
Posted : 16/02/2016 8:21 pm
I blew one of the rim trying to get it to seat properly. My ears rung for a week! Be careful not to over inflate. Once I sorted it out, it's stayed up perfectly with just a bit of Stan's on OO rims (ghetto with 24" cut down tube)
Posted : 16/02/2016 11:03 pm
I echo billoddies sentiments. Great front tyre for big rocky descending.
Posted : 16/02/2016 11:25 pm
