Chris King ISO hubs...
[Closed] Chris King ISO hubs are they worth the extra?
I've recently gone single speed and I'm after a single speed specific hub, always wanted a chris king hub but are they worth the 100+ extra over say a hope pro II trials? or are there similar performance hubs out there which cost less. thanks for any input
Posted : 21/06/2009 1:55 pm
The king hubs will offer absolutely zero performance improvements over pretty much any other hub including the Hope hub. Whether they are worth £100 extra? Well, that's largely down to how much you think it's worth having a component with CK written on it.
Posted : 21/06/2009 2:25 pm
DT Swiss would get the nod from me, lighter than King and less maintenance.
Posted : 21/06/2009 3:15 pm
Yes its worth the extra money, ive had a set {with the disc adapter} for 8 yrs, 1 service, had to undo the axle and tighten the preload on the bearings a few times over 8 yrs riding in the peaks, alps wales and scotland, i have seen countless sets of my friends wheels go to pieces in that time.Splash out on quality kit.
Posted : 21/06/2009 4:04 pm
I think Tune (230gm) is the lightest SS cassette hub then there's American Classic (244gm) and then Hope (295gm). Don't know about CK because I don't have one.
I think you should base your decision on technical merit - buy the hub which has the prettiest anodising 🙂
Works for me.
Posted : 21/06/2009 4:09 pm
 jeb
They are not really lighter, or faster, but they are so simple to work, regrease, set preload on, that a monkey on crack can do it.
Mine has worked for 6 years.
I have before ruined dt 240, tunes, and i dont ride that sick.
I dont consider it a pimp object, just a part that plain works.
Posted : 21/06/2009 4:31 pm
toss a coin, if after seeing the result, you say to yourself "best of three" you have your answer!
Posted : 21/06/2009 4:34 pm
 viv
One thing I like about the CK iso hubs are the buzz they make - even at slow speeds - as opposed to the annoying ticks hopes give off - this is probably down to having many more teeth in the ratchet and helps make their pick up even more instant - any other hubs do this? - my hope dont....
Posted : 21/06/2009 6:09 pm
