Chris King Bottom B...
[Closed] Chris King Bottom Bracket Installation
Is it possible to do it with a shimano bottom bracket tool? is the grease injector really necessary or if i just put loads to start with that will do the job?
I have installed a few Shimano but this is the first CK, and the question here is really do it myself or take it to the shop...
Help!
Posted : 28/01/2011 8:37 am
 ojom
It is the same tool to install.
You do not need the grease tool from the off. Just when it needs re-greased.
Enjoy.
Posted : 28/01/2011 8:39 am
Injector's not necessary, but the point of the CK BB is that it can be re-greased.Not much advantage getting one if you don't bother re-greasing it.
Posted : 28/01/2011 8:44 am
awesome, thanks.
for the record - assuming i give the bike an average use (only weekend rig) how often do i need to re-grease it?
thanks again!
Posted : 28/01/2011 8:46 am
 ojom
Well that will then depend on conditions etc
fret not, just take it as it comes. 8)
Posted : 28/01/2011 8:48 am
I bought one when they first came out just because you could re-grease the bearings. The grease gun didn't come out until a lot later so I have just popped the bearing cover off, washed them out with wd40 and re-greased. I haven't bothered with the gun because the job is so easy. You have to take the crank off anyway so a couple of extra minutes is no trouble and at least you know you have removed all the dust, water etc.
Posted : 28/01/2011 9:32 am
