cheapest simplest w...
[Closed] cheapest simplest way to convert to single speed?
ok so i have a second bike i want to make a single speed to give it a go.its 24 speed and i dont really want to spend any money.thats the criterior! happy to keep the front dereuilier for now and even maybe the whole cassette so i can play with ratio's etc, its just the tensioner that i need to sort.can a rear derailer be used some how? i think i have seen it in use but how is it done or am i talking total crap and i just need a tensioning doofer thingy me bob.
links appretiated where ness.
Posted : 22/12/2009 10:56 pm
Just stop changing gear!
Posted : 22/12/2009 11:03 pm
 Rich
If you're happy to keep the front dérailleur, cassette and even use the rear dérailleur then the cheapest simplest way is just not to change gear!
Or adjust the screws on the dérailleurs so you cant change gear.
Though you will miss out on many of the benefits of singlespeeding such as less to break and lower weight, it would maybe give you a little insight?
Posted : 22/12/2009 11:04 pm
Spacer kit + tensioner + 4*SS chainring bolts. £35
If you want it properly smooth: BMX chain and a non-ramped front ring. £22
Posted : 22/12/2009 11:06 pm
chears daffy.can someone enlighten me as to tensioners.what would be good and i guess it fits to the hanger yes?
Posted : 22/12/2009 11:27 pm
http://www.charliethebikemonger.com/userimages/procart2.htm
ask Charlie - super helpful
Posted : 22/12/2009 11:30 pm
Surly and On-one do reasonable tensioners. For the most part they attach to the mech hanger and push up or down. Up is apparently better...
Posted : 23/12/2009 10:06 am
+1
Posted : 23/12/2009 11:12 am
Chainring http://www.velosolo.co.uk/shopcrank.html £17
tensioner, spacers, sprocket [url= http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m38.l1313&_nkw=singlespeed&_sacat=See-All-Categories ]EBAY LINKY[/url] £20
BMX Chain from Halfords £7
Posted : 23/12/2009 12:23 pm
if i have semi-horizontal drop outs, as is common on really cheap frames (as this is) would this allow enough adjustment to not need a tensioner?
Posted : 23/12/2009 5:26 pm
just to repeat this is an experiment not a "proper" build.
Surely if you want super cheap find the gear ratio you would want and then try riding without changing gear. If you're willing to spend a little get a tensioner & converter (from on-one for £20 for both) and ditch all your gears apart form still having 3 rings up front.
Posted : 24/12/2009 12:31 pm
Maybe but it depends how much room you have to play with (up and back I assume). A half-link or a half-link chain might make it more do-able/easier without a tensioner.
Posted : 24/12/2009 12:35 pm
I converted for about £2.
Old cassette spacers to pad out the freewheel with it's one cog, taken from the old cassette.
Shorten the chain a bit (trial and error)
Old knackered rear mech as tensioner, a good one would work perfectly well too if yours is fine. Set the limit screws in the right place.
Remove front mech, shifters and cables.
Spent the £2 on some shorter chainring bolts. Use middle ring in middle ring position, adjust chain line by moving the spacers around.
Posted : 24/12/2009 5:32 pm
