Hey does anyone know the cheapest UK based retailer that sells the SLX M675 Brake? It doesn't have to come with rotors.
Thanks
Get a groupset from merlin and sell the bits you don't need on here
Would you actually be any better off?
Rose Bikes? Or at least it was.
Edit! Not UK.
Yeh i have looked at rose bikes however they sell the brakes with the levers swapped which would mean i'd have to switch them. Not sure on how to do that!
How much do you think i could get for a brand new groupset as listed above from merlin but without the brakes?
Sorry for my nooby ness. Im 17 and don't wan't to risk all my limited moneysss haha
got mine from tweeks
http://www.tweekscycles.com/components/disc-brakes/shimano-slx-m675-disc-brake
cheaper than CRC, not compared against anywhere else
Thanks for that rocketdog. I think ill just get them from rose bikes even though originally i said i wouldn't. I might as well learn how to swap the hoses anyway eh.
I like the idea of buying the groupset then selling the rest on but it might take a while to completely sell everything.
Cheers guys
there's a couple of vids on youtube that do step by step guide to swapping hose's on shimano brakes, have a search
Will do! Thanks for the help peeps
Just get them from rosebikes, it is very easy to swap the levers over- takes a few minutes and doesn't require bleeding them.
Also don't forget £10 voucher if you like them on Facebook.
Why swap them over? I ride with the rear on the right...always thought it was normal. Probs a throwback from my bmx days. One brake ( Rear ) on the right.
I'm looking at a set of these at the moment and i think Rose are slightly cheaper but out of stock for around 6 weeks.
Merlin are £75 an end and 3% off with Quidco.
Tymbian, I really wouldn't like to have them reversed as im sure i would just go OTH.
MrTall, yeh they are out of stock but I can't buy them at the moment anyway as I need to get some funds together! 🙂
Gaberin, Thanks for that money saving tip! Every little helps
Not bought any brakes ,but I can definetly recommend Rose Bikes.
Just had my first order with them,received within 2 days of them being despatched(Had UK orders from other companies take much longer)got a free gym bag thing and also 10%off with the facebook likey.
Regards the 10% off,it did not show at checkout but does show on my receipt and via bank,just make sure you paste the code into the comments section as well.
Captaintomo,
I wouldn't worry about buying brakes with the levers the wrong way round as you would have to shorten hoses on a UK set, so It's just as easy to swap them at the same time.
The worst thing that can happen is that you learn to bleed brakes - and that's not a bad thing.
