Cheapest Place For ...
[Closed] Cheapest Place For Stans Rimstrips?
 P20
As per title, to fit 355s. Cheers ๐Ÿ˜€
Posted : 07/12/2009 7:03 pm
You don't need rimstrips - just yellow tape and a valve.
Posted : 07/12/2009 7:20 pm
 P20
Even if your using non ust tyres?
Posted : 07/12/2009 7:57 pm
Yes, just without the valve!
(edit) that's if you're running them non tubeless..
Posted : 07/12/2009 8:04 pm
 P20
I thought you needed the yellow tape under the rimstrip. But you can just run the yellow tape, bang in a valve and that's it? Sounds too simple!!!
Posted : 07/12/2009 9:24 pm
 DeeW
AFAIK: if running tubeless you can either run:
yellow tape and ust tyres
yellow tape and normal tyres (but may not seal well & may burp)
any tape and rim strip and non-ust tyres
If you are running tubes you will need some rim tape (any kind should be fine).
Posted : 07/12/2009 10:49 pm
 DeeW
BTW not sure if they are cheapest but JustRidingALong is the first stop for all things tubeless.
 P20
Cheers guys
Posted : 07/12/2009 10:51 pm
