Cheaper alternative...
[Closed] Cheaper alternative to Park wheel holder?
[#11032519]
Has anyone seen a cheaper alternative to Park Tools wheel holder
For several jobs this looks like a really good idea. But I wouldn't use it enough to justify the £100. They do a cheaper one, but that doesn't do the 45° angle which is what I'd use most.
I can appreciate there's quite a lot of machining in the Park Tool, but if I had a lathe handy I'd just make it myself.
Posted : 02/02/2020 3:46 pm
I made my own, for the axles I used pit bike axles 12 and 15mm. Very cheap on eBay and for the very infrequent times I have a wheel with a different axle I’ll just go old school.
For the body I used a bit of flat bar folded over, holes drilled to screw the above axles into.
started as proof of concept and ended up being the end version, might make a mk2 to address minor niggles.
Posted : 02/02/2020 4:34 pm
Yes that would work perfectly (wondering why I didn't think of it!).
I could probably use threaded rod for axles too, although they might scratch the hub.
To the garage!
Posted : 04/02/2020 8:25 am
