Shimano Mt800 Insta...
[Closed] Shimano Mt800 Install/adaptor PITA
[#11032622]
Hi all, i am trying to install the new smaller type hollowtech 2 bb using the supplied adaptor and it's driving me nuts! The adaptor doesnt fit inside my regular ice toolz bb cup tool. The adaptor says to use shimano spanner tl-fc 32, am i assuming this spanner is bigger than my existing tool to fit the adaptor inside it? I would rather install with a torque wrench and at this point im not sure which tool to even buy to fit it. Driving me nuts as its my first new build in years and in keen to crack on! Please help....
Posted : 02/02/2020 5:15 pm
Buy one of these...
https://www.parktool.com/product/bottom-bracket-tool-bbt-59-2?
Posted : 02/02/2020 5:23 pm
TL-FC25 should fit in a "standard" hollowtech BB tool, however some brands are a little tighter/looser than others, you might need to press it in.
TL-FC37 is the Shimano socket type tool, park etc also do socket type tool BBT 59.2, 16 Notch, 41mm OD for MT800.
Hollowtech was 16 notch, 44mm, new XTR/DA is 16 notch 39mm.
Its stupid.
Posted : 02/02/2020 5:26 pm
The plastic adapter should fit snuggly into a "standard" Hollowtech tool. Maybe you just need to be a bit firmer 😉
Posted : 02/02/2020 5:28 pm
thanks all for the help, ive tried pretty hard to get it to sit inside my existing adaptor but it wont go, might try to hammer it in and if that fails i will buy a new tool..
Posted : 02/02/2020 5:38 pm
Fitted one of these yesterday. Had to tap the adaptor into my superstar ht2 tool. Was a tight fit but went in ok.
Posted : 02/02/2020 5:49 pm
I have a lezyne socket type that attaches to my digital torque wrench and the adapter fits snugly, just requires a firm push.
Posted : 02/02/2020 8:17 pm
Really? One of the least likely candidates for torque wrench use surely?
Posted : 02/02/2020 9:22 pm
I had the same issue where the plastic adapter would not fit into my bb tool ( I had a socket type) and ended up buying a new spanner style to fit it.
Posted : 02/02/2020 10:26 pm
One of the most likely candidates for torque wrench use if you have a quality higher range one that torques both ways, I always use mine for bb installation, how else do you judge 40nm. My bb cups are perfectly, equally torqued along with my pedals and cassette as well as everything else with my 1/4" torque wrench.
Posted : 03/02/2020 10:01 am
