Cheap, tubeless rea...
[Closed] Cheap, tubeless ready gravel/cx tyres?
Hi all, I'm fed up of punctures on my commuter (on 35mm Kenda SB8s) so I need something tubeless ready. I ride a mix of gravelly and muddy towpath and road so I basically need a lightly treaded CX tyre, which I think is called a gravel tyre these days. Similar tread to the SB8 would be ideal.
My searching has suggested tubeless cx tyres are relatively new and pricey at £35+ each. The Bontrager CX0 TLR looks great, but too expensive. Anyone have any cheaper suggestions?
Posted : 02/11/2015 12:39 pm
Specialised Triggers? I don't think they're that expensive & tubeless a treat.
Posted : 02/11/2015 12:42 pm
They look great, but £35 each for the Trigger 2Bliss model.
Posted : 02/11/2015 12:44 pm
Not sure what I paid, old mate did us a deal.
Posted : 02/11/2015 12:46 pm
Schwable Marathorn with a tube. or Land Cruisers which are better off-road.
Most of the tubeless ready tyres I've seen are £30+
Posted : 02/11/2015 12:47 pm
I'm not using tubeless specific tyres though I am using Stans Arch Ex rims which work really well. Currently on Nobby Nics in 35mm
Posted : 02/11/2015 12:48 pm
Hi all, [s]I'm [/s] I was fed up of punctures on my commuter [s](on 35mm Kenda SB8s)[/s] so I [s]need something tubeless ready[/s] put some Stans fluid in the tubes.
Posted : 02/11/2015 12:50 pm
Have you tried tubelessing the SB8s? Can't say I thought they were particularly puncture prone myself, and they sound a good fit for your commute.
Posted : 02/11/2015 1:06 pm
Stans in tubes is nowhere near as good as full tubeless (I tried it before going tubeless).
Posted : 02/11/2015 2:00 pm
I can't believe you're even considering using the same tyres for gravel AND muddy CX bits.
Sorry I have nothing useful to add
Posted : 02/11/2015 2:05 pm
I think he means a muddy tow path on his commute. Not muddy CX. It's a bit difficult to avoid mud all together when riding at this time of year, even on the country roads!
I suggested touring style tyres because cx tyres are not generally know for puncture protection.
One thought, you are putting the correct size tube in? A road tube fits and works, but you tend to get more punctures.
Posted : 02/11/2015 2:22 pm
Serious suggestion, have you tried tubelessing what you have on currently? Should seal thorn type punctures OK (although they will seal better in a tubeless ready or UST tyre)
Posted : 02/11/2015 2:34 pm
A lot of people recommend not running the SB8s tubeless due to a very thin carcass. I don't fancy it going bang on me! Although this article seems to say they work: http://www.cxmagazine.com/going-tubeless-cyclocross-tires-racing-recommendations
Traildog - touring tyres are an option, but I'd rather go tubeless if possible. I am running the correct inner tube in the back (patched it twice in 3 commutes now!) the front does have a road tube in though.
The Schwalbe CX comps look a good tread, but not sure on tubeless compatibility.
Regarding stans in an inner tube - I guess special tubes with a removable valve core are needed?
Posted : 02/11/2015 3:22 pm
Right, going to give the rear SB8 a go tubeless tonight as it has gone down again today!
Posted : 02/11/2015 5:40 pm
 jonk
I've been running Schwalbe CX comps tubeless for almost 2 years now. They go up fine but you need a little more sealant because it leaks out of the sidewalls for the first few days. Once sealed i add a little more through the valve stem. They last around 1000 miles on the rear and 2000 on the front with a mixture of road and offroad riding. I've never had any major issues with them and because they have a kevlar belt they seem to defend well against cuts from glass. I go back to these because they grip well and can be had for a tenner each.
Posted : 02/11/2015 5:58 pm
Really? seen Ron and Ralph in that size but not a Nic.
Posted : 02/11/2015 6:44 pm
