Cheap SS crank - 10...
[Closed] Cheap SS crank - 104 BCD options
[#9503570]
I've not ridden the MTB for 5 years, mostly road now. Just pulled it down from the loft and found the cranks got a massive chunk missing from one of the chainring bolt areas.
Cheapest replacement options? Its currently on a decent running square taper, the below looks fine but I'm not sure if you can split the outer and inner rings off?
https://www.amazon.co.uk/Shimano-Acera-M371-175-Chain/dp/B009WICGT4/ref=sr_1_10?s=cycling&ie=UTF8&qid=1503156950&sr=1-10&keywords=shimano+square+taper
Posted : 19/08/2017 4:50 pm
