Cheap Rockshox Rev ...
[Closed] Cheap Rockshox Rev Service
Looking to do a full service on my 2012 revelations.
Wheres cheapest for all of the following:
Wiper seals and foam rings
Air spring kit
Motion control kit
I'm a bit confused which kits contain what. For example, does this kit [url= http://www.bicyclehero.com/gb/rockshox-am-12-service-kit-basic-revelation-dual-air.html?gclid=COPs_oaw4bUCFY3LtAodHhMASQ ]here[/url] contain all the items that I will need?
Finally, the suspension fluid that I need is 5 and 15 wt. Are there any that I need to avoid, or will any old fluid do?
Cheers in advance for the help!
Posted : 03/03/2013 8:24 pm
that looks like a good deal actually. i normally use this guy (reba, i think rev is similar anyone know for sure?)
http://www.ebay.co.uk/itm/Rock-Shox-Reba-Race-O-rings-Seals-Crush-Washer-kit-/181079489613?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2a292dbc4d
but you get wipers also with yours and it'll def fit so good deal.
yep any fork oil will work, but might feel a bit different. i use SVI. the best is meant to be Red line? if you want to get spendy.
generally you can do several oil changes without changing any parts, even the crush washers can be reused loads of times IME. by changing seals early you might prevent a blowout on a ride but you might also introduce a problem after the service!
edit: ah wait that site is based in Korea, shipping is not so cheap. might still be a good deal though.
Posted : 03/03/2013 9:31 pm
 LoCo
The RRP on the link in the OP's post is incorrect for that service kit it's actually £14.99, cheeky!
We have those kits in stock, they're a pretty good deal as you get all the seals, glide rings and the wipers and foams as opposed to the older kits, separte wipers/damper seals /air seals. 😀
Our site is being updated to be current and match all the new sets of seal kits with the older forks and listing our new 'pattern' kits so everything will be cheaper and more comprehensive soon 😀
Posted : 03/03/2013 9:45 pm
Ah nice one, so other than oil that kit has everything I will need.
Ill probably give you a call tomo Loco and order some if I can get them from you for the same price.
Posted : 03/03/2013 11:07 pm
hey Loco, if you update your site will that be here soon please?
http://locotuning.co.uk/rockshox-spare-parts.html
i be needing that kit for both sides and wipers, only ones i can see are separate air and damper side and wipers which is like £60 or something silly for all 3.
like this http://www.tftunedshox.com/Catalogue/Shop-RockShox/RockShox/RockShox-Revelation-Parts
cheers (so RS just dropped the prices? sweet another plus for RS)
Posted : 05/03/2013 6:39 pm
