I have always used my Galaxy S as a GPS (my tracks, endomondo ect...) and have been looking at the Garmin edge range but do not have Garmin edge money. There was a thread on here last night about GPS and someone mentioned the pulse mini. Does anyone else use the pulse mini or a small android smart phone as a dedicated GPS.?
It seems a no brainer really, they can be picked up for peanuts and will function perfectly as a GPS, they can be hacked and are multifunctional. The only downside would be attaching the thing to the bike but I am sure a case and a couple of cable ties will overcome this.
Battery life? You can get 12 hours+ out of a Satmap, 3-4 from a phone.
morgan computers have an android unit on cheap.
cant vouch for it so do research access to android market etc.
surely you can get an android on payg for <than 90 quid?
do you use the GPS to navigate?
I only use my phone to record the route. Never felt the need to have a GPS to know where I'm going.
My phone lives in the camelbak no probs with signal.
Mr Agreeable - Member
I reckon my desire S would do at least 6 hours with GPS on - more if I switched off mobile signal and wifi...
From a quick google the pulse mini is about £65. Add in a mount and waterproofing and I reckon you'll be adding at least £20, probably more. For not a lot more than that you could get a second hand Garmin Edge 605 which is waterproof, has mapping (free version available which IME is as good as OS) and works very well as a GPS which is fundamentally what you want. My Desire S works amazingly well considering it's a phone but it's definitely not as reliable or consistent as my Garmin.
£40 new is the cheapest I found this morning.
I thought about it. Thought about battery life, mounting, capacitive screen not behaving with rain drops, etc.
Then I bought a Garmin.
I could be interested since my mobile is old...but the pulse mini is discontinued from what I can see?
I've used my galaxy s for this in a waterproof touchscreen case I got free from MBUK. Works well, but having the screen on constantly for nav (oruxmaps with OS mapping) absolutely kills the battery.
Seems that way but XDA have some support for it.
But would you be able to refrain from checking STW? 😉
Another option would be a second hand pocket PC (iPaq or similar) running Memory Map, with a separate GPS receiver and a high capacity battery. Should be doable for about £100 if you already have the software, but quite a fiddly, fragile and inelegant solution.
I use an old Nokia 5800 running Viewranger in a waterproof phone bag (from Decathlon)which is then velcroed to the stem. Looks a bit crap but it works fine. The best things about the 5800 are the battery life (8+ hours with viewranger and GPS) ,the resitive screen (so I can use gloves and operate it whilst it's inside the waterproof bag) and they are dirt cheap off ebay.
