Changing triple cra...
[Closed] Changing triple crankset for single ring
[#9418028]
Asking on behalf of a friend here who has a 2013 Jekyll 4.
Its running a triple SRAM S1000 crankset which is quite beat up so he is thinking of going to a single ring up front.
Can he keep the esixting crankset and fit a new ring or will he need a new one?
If so if there any recommendations, its using a BB30 bottom bracket and 10s cassette.
Thanks
Posted : 04/07/2017 10:15 pm
http://singletrackworld.com/forum/topic/1x-conversion
Yes just fit a new ring in the middle position. They are all much of a muchness but personally I've had good experience with raceface.
Posted : 04/07/2017 10:25 pm
Thanks.
Just checked over his bike and the outer ring states 104BCD, is the following correct:
Remove crankset and rings
Remove derailleur/shifter
fit new 34T chainring to existing crankset with shorter bolts (still need to find these)
Replace crankset and alter chain length?
Posted : 11/07/2017 12:48 pm
you can shorten the bolts with a file, don't need to buy new ones. remember being told to "screw them together backwards and file the difference". Not sure if they were being rude 🙂
Posted : 11/07/2017 2:51 pm
Are the cranks the type with the removable spider (3 torx bolts on the back) - if so you can remove that and fit a direct mount ring.
direct mount and 104bcd rings are cheap cheap on aliexpress.
I did the same, went with an 11-46 xt cassette, rear mech and shifter.
Posted : 11/07/2017 3:08 pm
Its the same as below:
Where do you purchase the shorter bolts from?
Posted : 11/07/2017 3:17 pm
search for "single chainring bolts".
Posted : 11/07/2017 3:28 pm
Or use these chainring tab shims and the existing bolts:
http://www.chainreactioncycles.com/race-face-chainring-tab-shims/rp-prod117551
I think some RaceFace single rings may even come with some.
Posted : 11/07/2017 3:46 pm
Charlie the Bike Monger sells short bolts that I can vouch for. ID I think?
Posted : 11/07/2017 3:47 pm
Cheers guys.
Could someone confirm the above procedure would be correct?
Posted : 13/07/2017 1:21 pm
I buy these bolts from tredz, both parts are Allen key
https://www.tredz.co.uk/.Truvativ-Chainring-Bolt-Kit-4-Arm_55508.htm
The have the hope retainer rings on offer also (still not the cheapest rings though)
Posted : 13/07/2017 3:44 pm
Thanks. I will get them on order.
Can someone confirm the above procedure is correct?
Posted : 16/07/2017 3:09 pm
 ctk
Yep.
Posted : 16/07/2017 6:30 pm
If you buy some chainrings they come with the thread built in so you can just use half of the existing bolts. I have them on my bike, oval 32t ones. Works Components I think is the brand but could be wrong.
Posted : 16/07/2017 7:16 pm
