It looks simple on YouTube, undo the threaded barrel that is attached to the small gear chain. Remove the wheel, take off the circlip and cog. Refit in reverse.
Should the bike be in a particular gear lowest or highest?
Posted : 27/01/2018 9:22 pm
Once you unscrew the cable adjuster the hub will return gear three so it does not really matter what gear it’s in.
Just removing the clip will be fun bit
Posted : 27/01/2018 9:41 pm
It only takes seconds to change the cog when you get the knack.
Posted : 27/01/2018 11:00 pm
Aye it does , but that first time is always funny to watch.
I’m not a fan of snap rings with no ears especially after doing some speed play pedals this week
Posted : 27/01/2018 11:21 pm
