Changing fork rake ...
Changing fork rake on a Caad X
I have recently replaced the carbon fork on my Planet X tempest with a fox tc (which is ace). I subsequently have the old carbon fork going spare*
I also have a Caad X which I occasionally use (mainly in road) that has a heavy alu steerer fork, with a post mount brake. I’d like to upgrade the groupset to full hydro by buying one of those ltwoo group sets, however they are flat mount (rear of Caad X is flat mount). If I fit the old selcof fork that’ll solve the brake issue and also reduces weight
the key issue is the selcof fork has a rake of 45, the Caad X of 55. How will it affect handling. Given I plan to use the Caad X mainly as a spare winter roadie, will it actually improve handling for that purpose?
* ignoring the fact the selcof fork has recently been in the news for snapping in two..
Posted : 17/12/2023 8:52 pm
You have the fork. You have the bike. It wouldn't take many minutes to temporarily fit it without the front brake and take it for a cautious spin around the block.  You'll then know what it does to the handling.
Posted : 17/12/2023 9:30 pm
jameso and jameso reacted
Shortening offset is the same as slackening the headtube angle, increasing trail which will slow down handling a touch - you may notice it the first time you ride it, but will probably get used to it.
Posted : 17/12/2023 10:32 pm
Ah that’s not so good. The Caad X already has a 71 degree ha, so I want to steepen it, rather than slacken.
Posted : 17/12/2023 10:47 pm
Its not the same as changing head angle - rake is head angle, offset is what you are measuring that has an effect on trail - shorter offset = longer trail = more stability and slower steering
Personally I cannot tell the difference with 44 or 55 mm offset.  maybe just me being an insensitive clod
Posted : 17/12/2023 11:23 pm
Something else to consider is toe overlap - your front wheel will be closer.
Posted : 18/12/2023 8:51 am
Doesn't really make any difference to me either. Bike feels a bit different on first ride (probably because I know I have changed it so am looking for differences), after that I have forgotten all about it.
Posted : 18/12/2023 10:02 am
 mert
What's the A-C of each fork?
I've done back to back on a road bike (same model fork available in two different rakes) switched back after a couple of weeks and 500 miles, wasn't fun...
Posted : 18/12/2023 10:11 am
Wouldn't worry about it. Three road bikes with different rakes/geometry and can't tell.
Posted : 18/12/2023 10:25 am
They (Cannondale) had a recall on the CAADX for the fork a few years ago. Make sure you've been done as (IIRC), the spontaneous failures were quite exciting...
Posted : 18/12/2023 10:30 am
They (Cannondale) had a recall on the CAADX for the fork a few years ago. Make sure you’ve been done as (IIRC), the spontaneous failures were quite exciting…
I was going to say that, but that applied to the older post mount framed bikes, not sure it included the newer ones.
Still worth checking though as I got a new carbon fork for mine and I wasn't even the original owner. Just had to send a few photos and serial numbers to my local-ish Cannondale LBS. Only complaint was they re-fitted the original knackered headset, if they'd mentioned it at the time I'd happily have paid for a new one rather than have to prise the rusty crown race off a new set of carbon forks.
Posted : 18/12/2023 10:46 am
