Changing brakes fro...
[Closed] Changing brakes from Elixir CR to XT
Want to finally get rid of my useless Elixir CR for shimano SLX or XT.
Is it as simple as swapping the units or do I need different post mounts?
I don't plan to change the discs, basically I just want to bolt on new levers/calipers.
Any advice would be appreciated.
Posted : 06/09/2014 7:39 pm
You may need to fettle the mounts using spacers, but they should work just fine.
Posted : 06/09/2014 8:16 pm
The mounts might foul the caliper, but worth trying and then getting new mounts If you have a problem...
Posted : 06/09/2014 8:49 pm
Went from elixir to shimano just had to remove the spacers
Posted : 06/09/2014 9:03 pm
How much for the old CR,s?
Posted : 06/09/2014 9:10 pm
Thanks why could the mounts cause a problem? Because they aren't shimano specific ones?
NorthCountryBoy: er no idea, they are a few years old, white lever bodies/calipers, pads worn but a bit of meat left, and a brand new bleed kit unused. Message me an offer I'm sure we can sort something.
Posted : 06/09/2014 9:27 pm
I've got both. The mounts just need shimming.
I get amused when I see these threads about Avids. Cheap Avids for us that know how to look after them!
Posted : 07/09/2014 1:29 am
Skinnyboy, would you care to share your secrets? I have a set of avid elixirs on a bike which are in need of a bleed. Cheers
Posted : 07/09/2014 5:53 am
I went from Elixirs to Deore, just bolted straight on, no spacers etc.
I wouldn't pay for XT when Deore are fantastic
Posted : 07/09/2014 5:59 am
Not sure why it's amusing, I don't like the elixir CR compared to the xt on another bike that's all.
Plenty of avid fans out there so they can't be a bad brake.
My biggest beef with the exilir is inconsistent pad alignment, I'm sure it's an error on my part but take a wheell out, put it back in and 50%+ of the time it rubs, I've never experienced that with My XT ones. I prefer a fuss free ride and setup.
I'd happily save the money on buying new brakes if someone can recommend how I fix the problem 😀
Posted : 07/09/2014 9:03 am
I don't know mate, for me in have never had problems with avid brakes from BB7's, Juicys and Elixirs. For me the secret is to follow the instructions to a tee. Both installing and bleeding. Use genuine kit as well. I think a lot of people think they can jam on a syringe and push the fluid up the guts and get a good bleed. I've seen some muppetry akin to this in the flesh at a LBS near me.
For me they work and always have given consistent braking and performance as good as the XTs I have on another bike.
Posted : 07/09/2014 9:26 am
Well all sorted, wasn't that tricky really.
Set of Elixir CR's not for sale!
Thanks
Posted : 07/09/2014 9:37 pm
So how did you cure them?? 😀
Posted : 08/09/2014 10:07 pm
Er 😳 it meant to say NOW for sale not not!
Stole XT off other bike and all fitted fairly easily. Pushed shimano mount for front and existing one on the back.
Can't believe I've waited all these years to do this!
Posted : 08/09/2014 11:15 pm
how much for the CR`s?
Posted : 09/09/2014 9:41 pm
I have no idea, I have caplipers, pads (not new), levers and hoses all as they came off the bike. I also have a brand new bleed kit that I never got around to using (I think £25 on CRC).
£50 + postage for it all?
Posted : 11/09/2014 10:06 am
If it's the same bleed kit as the Reverb, you may want to keep it (if you've got or are planning to get one that is).
Posted : 11/09/2014 10:11 am
Ah right thanks AlexSimon, just got one of those the other week!
Posted : 11/09/2014 7:14 pm
Worth a double-check to see if it's the same.
Posted : 12/09/2014 8:03 am
Will do thanks
Posted : 12/09/2014 8:49 am
Avids run on DOT fluid, Reverbs are mineral oil based. Mixing the two up will result in sudden and catastrophic seal-death. 🙁
(You can probably get away with it by thoroughly rinsing out the syringes every time you use them, though.)
Posted : 12/09/2014 9:50 am
Ah OK, solves that problem then, just realised I have a bleed kit supplied with the reverb anyway.
Massive eBay session coming up, lots of bits to sell!
Posted : 12/09/2014 11:04 am
Ill give you £25 for the CRs 🙂
Posted : 12/09/2014 12:04 pm
I have some CR's and I'm looking to buy some Deores to replace them.
If someone is interested, I'll take pictures and they can make me an offer. I'll tell you now they are quite well ridden and the rear brake lever is missing a bushing which makes the lever a bit floppy - but they work great still! (I seem to be one of the few that has them set up right)
If anyone is interested, let me know.
Posted : 12/09/2014 3:09 pm
Northcountryboy: sure, is your email address on your profile your current one?
I can send you a pic of them just so you're sure. £25 + postage but no profit on the postage I assure you.
Posted : 12/09/2014 5:39 pm
Yep email in profile ty
Posted : 13/09/2014 7:59 am
OK I'll sort that tomorrow
Posted : 13/09/2014 6:05 pm
My avids have been ok whereas the xts brilliant from day one with no bleed dispute shortening hoses. Shimano brakes are brill for the price on crc
Posted : 13/09/2014 7:16 pm
