Changing Brake Roto...
[Closed] Changing Brake Rotors
Do i really need a torque wrench to do this?
Posted : 22/09/2012 6:58 pm
No just tighten them up by hand and put some locktite on each bolt thats what i have done with my Hope Rotors over the years.
Posted : 22/09/2012 7:00 pm
You do if you want to tighten the bolts up to the correct torque settings.
But if your not bothered, then no.
(That's not a flippant answer, I changed mine without a torque wrench, and I'm still alive a few months later ๐Ÿ™‚ )
Posted : 22/09/2012 7:01 pm
Do you know how tight is too tight?
The difference will be when you have to remove them, strip or snap the bolt and end up with a stub stuck in your hub ๐Ÿ™‚
Threadlock, 2-3 finger tight and you'll be alright!
Posted : 22/09/2012 7:05 pm
Cheers Chaps, I've never done this before and thought a torque wrench might be a bit OTT. So with the locktite;
first question loctite as in superglue?
Second question put it around the bolts after I've tightened them up, or before I tighten them?
Apologies if I'm being dim.
Posted : 22/09/2012 7:08 pm
no not as in superglue!
Get yourself one of these (eg from Halfords) http://www.ebay.co.uk/itm/LOCTITE-248-THREADLOCKER-medium-STRENGTH-19G-/380323837897#vi-content
as it will last ages and stop you putting too much on - it's like a lipstick. You just dab a bit onto the bolth threads then tighten them up. Do not do them too tight, the threadlock will do it's job and prevent them corroding together too - ie like a grease that then sets to stop it coming loose.
Posted : 22/09/2012 7:11 pm
