Changing 160mm roto...
[Closed] Changing 160mm rotor to 180mm
Thinking of buying a new wheel set for my Anthem. The new front wheel comes with a 180mm rotor and I'm currently running 160mm.
Obviously I could swap the rotors but if I kept the 180mm what would I need to do to the caliper to accommodate it? (XT caliper if it makes a difference).
Cheers in advance.
Posted : 09/05/2013 10:19 pm
Just a different adapter between caliper and fork (you might not have one at all at the moment, if it's post mount)
Posted : 09/05/2013 10:21 pm
Post mount caliper to post mount fork?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=54881 ]you need this[/url]
Post mount caliper to IS fork?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=17390 ]you need this[/url]
Posted : 09/05/2013 10:26 pm
OK, now I'm forced to ask another dumb question...... post mount or IS mount? What's the difference?
Posted : 09/05/2013 10:31 pm
First result out of google with pics
[url= http://www.bikeman.com/bicycle-repair-tech-info/bikeman-tech-info/1638-51mm-international-standard-74mm-post-mount ]Brake mounts[/url]
Posted : 09/05/2013 10:37 pm
Nice one, cheers.
Posted : 09/05/2013 10:44 pm
