Chainring to chains...
[Closed] Chainring to chainstay clearance ..... What's too little?
I am just building up a Kinesis FF29 as an XC racey HT.
I have a 32t oval ring in the middle posistion that because of the oval is similar to a 34t ring in height and due to the oval sits away from the tabs of the chain set.
I have maybe 1.5mm clearance at the chain stay.
This is likely to end in tears isn't it.
Should I just find a 32t round ring?
Posted : 16/02/2017 11:00 pm
1.5 mm should be plenty - how much will things flex to close up that clearance. My Genesis ioid had about that as stock
Posted : 16/02/2017 11:04 pm
I have the max size chainring fitted to my bike that the chainstay would allow and there is probably less than 1mm clearance. Had no problems in over 1 year of riding.
Posted : 17/02/2017 11:17 am
I used to run mine with a 34t ring as a single speed, no issues
Posted : 17/02/2017 11:52 am
