chainring bolt
chainring bolt
[#12974470]
Hallo! I have this crankset
https://www.sram.com/en/truvativ/models/fc-frx-a1
What is the exact type of bolts for the chainrings (shown in the red box)?
</p>
Posted : 22/09/2023 1:38 pm
google Chain ring bolts, available in all colours,
6.5mm (m8) x 5.5mm should be long enough for through 2 rings
Posted : 22/09/2023 2:53 pm
You need standard 2x ones, not 1x ones.
https://www.chainreactioncycles.com/search?query=chainring%20bolts
Posted : 22/09/2023 2:59 pm
Surely that depends on what they plan to do with it?
2x if mounting 2 rings or ring and bashguard.
1x if mounting 1 ring.
Posted : 22/09/2023 4:49 pm
Surely they'd have mentioned if they were changing spec, as it stands it's a chainring bolt for a double they need.
Posted : 22/09/2023 8:04 pm
oldnpastit reacted
Thank you!
2x  -> mounting 2 rings
Will both of the below be ok?
https://r2-bike.com/RACE-FACE-Chainring-Bolts-5-Pics
or these
https://www.bike-discount.de/en/shimano-slx-chainring-bolts-for-fc-m7000/m672-4-pieces
Posted : 22/09/2023 9:38 pm
Yep, don't see why not.
Posted : 22/09/2023 10:52 pm
Surely they’d have mentioned if they were changing spec
Are you new here? Unless someone says something explicitly all bets are off, hence I accounted for both eventualities.
Posted : 23/09/2023 11:43 am
Or maybe you're just a cantankerous old fart 😁
Posted : 23/09/2023 8:56 pm
